SOLVED Missing "/conf/base/etc" in jail?
Naesstrom
Moving from transmission to qbit since I want it to unrar the files and never got that working. QB is all set up and working fine but when I try to install OVPN I've run into some problem.
One of the commands are
echo 'openvpn_enable="YES"' >> /etc/rc.conf && echo 'openvpn_enable="YES"' >> /conf/base/etc/rc.conf
but everytime I try to run that I get /conf/base/etc/rc.conf: No such file or directory. since I don't have the /conf/base/etc/ directory. Have I screwed something up when creating the jail or am I just being stupid and missing something?
Patrick M. Hausen
This directory should not be there and you should not write anything in that place. Who told you to do that?
/conf is a directory used in diskless and/or NanoBSD installations and not in regular FreeBSD like inside a jail.
Naesstrom
Their guide to install it on freenas have one step that looks like:
echo 'openvpn_configfile="/usr/local/etc/openvpn/openvpn.conf"' >> /etc/rc.conf && echo 'openvpn_configfile="/usr/local/etc/openvpn/openvpn.conf"' >> /conf/base/etc/rc.conf
Well that explains why it failed atleast, tried doing the setup but skipping that part but it wont start so I have contacted them again!
Patrick M. Hausen
Whose guide?
Don't skip the entire step. Just do the first part only:
HTH,
Patrick
Naesstrom
Whose guide?
Ah sorry, ovpn.se where I'm subscribed, their full guide is here https://www.ovpn.com/en/guides/freenas
HTH,
Patrick
Yeah sorry, I was just unclear, i skipped each command that referenced to /conf/etc/ and did the rest!
You could always forget about the location and use sysrc to worry about it for you...
sysrc openvpn_enable="YES"
Patrick M. Hausen
Outdated. Clearly they are referring to FreeNAS 8 or similar because they don't use iocage but jls and jexec.
As a general rule of thumb, if you want to install software X in a FreeNAS/TrueNAS jail, look for FreeBSD instructions:
Naesstrom
Thanks, followed that guide and atleast managed to get it installed but get a fatal error when starting it?
2021-04-08 15:19:08 ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=epair0b HWADDR=02:ff:60:5d:88:80
2021-04-08 15:19:08 Cannot allocate TUN/TAP dev dynamically
2021-04-08 15:19:08 Exiting due to fatal error
root@qbit:/
tun is enabled in the jail settings and I even compared all the other settings to my transmission jail where openvpn is working so don't think it's something I missed there
Patrick M. Hausen
Tun can be a bit picky with device node creation in the jail - I had to reboot the NAS once to whack the devfs or something into shape. From that point on it worked.
Lordy - ye olde computational axiom: When in doubt, reboot! :wink:
