mirror raid
theivper360
I am trying to use a mirror raid for my nas. I put a raid card in the system and when I go to volume manager to make a volume the nas will not let me make a volume it keeps giving a error. am I not suppose to use a raid card in free nas. I also seen where in gui where it asked if I want to use a mirror raid does freenas have there own raid software that I am suppose to use? If I do get the riad to work how will I know the raid is working?
theivper360
So it does use a software raid to mirror. How can i check to see if the other harddrive is copying the files
jgreco
Resident Grinch
That's not how ZFS works. Just check to see that both disks are part of your pool in a mirror vdev.
depasseg
FreeNAS Replicant
If you are concerned that the GUI isn't reporting correctly (or that you don't understand), just run "zpool status" at the command line:
Don't mind the failed disk, just look at the freenas-boot pool and notice the mirror-0 with 2 drives below it.
[root@freenas2] ~# zpool status
  pool: backup-tank2
state: DEGRADED
status: One or more devices has been taken offline by the administrator.
        Sufficient replicas exist for the pool to continue functioning in a
        degraded state.
action: Online the device using 'zpool online' or replace the device with
        'zpool replace'.
  scan: none requested
        backup-tank2                                    DEGRADED     0     0     0
          raidz1-0                                      DEGRADED     0     0     0
            gptid/6c9419be-9654-11e5-87db-001f33eaf869  ONLINE       0     0     0
            gptid/6d54648c-9654-11e5-87db-001f33eaf869  ONLINE       0     0     0
            gptid/6e0f6e32-9654-11e5-87db-001f33eaf869  ONLINE       0     0     0
            gptid/6ec82f73-9654-11e5-87db-001f33eaf869  ONLINE       0     0     0
            4440998044591230907                         OFFLINE      0     0     0  was /dev/gptid/9521ba9a-9654-11e5-87db-001f33eaf869
            gptid/9d5448ba-9654-11e5-87db-001f33eaf869  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 132K in 0h13m with 0 errors on Mon Nov  9 15:21:00 2015
        freenas-boot                                    ONLINE       0     0     0
          mirror-0                                      ONLINE       0     0     0
            gptid/1c4fbb56-c83f-11e4-ab84-001f33eaf869  ONLINE       0     0     0
            gptid/1caf62bd-c83f-11e4-ab84-001f33eaf869  ONLINE       0     0     0
[root@freenas2] ~#
theivper360
I got this message does this mean that it is backing up my files
NAME STATE READ WRITE CKS
UM
Data ONLINE 0 0
0
mirror-0 ONLINE 0 0
0
gptid/e054a7de-9aba-11e5-8426-00215a1ef9e5 ONLINE 0 0
0
gptid/e0af101e-9aba-11e5-8426-00215a1ef9e5 ONLINE 0 0
0
pool: freenas-boot
state: ONLINE
NAME STATE READ WRITE CKSUM
da0p2 ONLINE 0 0 0
[root@freenas ~]#
theivper360
  pool: backup-tank2
state: DEGRADED
        degraded state.
        'zpool replace'.
  pool: freenas-boot
state: ONLINE
[root@freenas2] ~#
I got this message does this mean its backing up my files
UM
Data ONLINE 0 0
0
mirror-0 ONLINE 0 0
0
0
0
pool: freenas-boot
state: ONLINE
da0p2 ONLINE 0 0 0
[root@freenas ~]#
depasseg
FreeNAS Replicant
If you paste it as "code", it's easier to read. :smile:
