Lucky you get that far, with, 8.3.0-BETA2-x64 (r12317M) when i try to use the latest plugin from
http://sourceforge.net/projects/fre...BETA2/x64/plugins/minidlna-1.0.24_1-amd64.pbi all i get is "Error: This file was not identified as in PBI format, it might as well be corrupt." I did manage to get it installed once on beta 1, on load my tv saw it for about 5 seconds but it crashed and unloaded itself on every reboot shortly there after.
Downloaded it several times and its same result every time... Managed to get transmission running with this build but it required also to use CHOWN command manually in both the torrent directory saving the torrent file and the directory for saving the torrent data, it seems that the CHOWN command needs to repeted in this manner everytime the transmission plugin is installed, and beware, somehow it happened that when i either updated the jail or the plugin that it deleted both the torrent data and torrent file direcory including over 2TB of data automatically without even asking.
Back up everything important before you go messing with it. Caveat emptor when it comes to plugins and the safety of your data with this current implementation. If it does what the transmission plugin does, when you update your jail or maybe even just the plugin, it will remove all the saved data in the jail directory for it as well.
