Mini-ITX NAS ( FreeNAS ) I've setup two interesting Boxes for those interested
IpNextGen
Ive written a little Wiki about two boxes im currently benching/testing with benches
There's a Green one and a Black one. One is the Backup FreeNAS ( To receive Replications and such ) and the other one with 3 NIC is for iscsi and fast I/O reponses.
Take a look at this : http://the.only.ipnextgen.net/fnas/
Thanks for your comments/Ideas/Suggestions
IpNextGen
Hi!
Yes, ill add the possible infos.
I wont modify the black one ( test with 4gb only, its kinda PITA to assemble, i dont want to touch it )
I was not using link aggregation yet. It will be in my future tests ( i need to get a dual nic for my motherboard ). When i will ill post switch specs.
Yes, ill post the Intel NAS toolkit results :)
Thank you for you interest
IpNextGen
There!
Added : HD Tune Pro Bench for ISCSI , Intel NAS Toolkit infos also ( For the Black HD NAS )
Ionized
Two quick questions about the case you are using:
1) The hot-swap hard drive bays have a backplane that is advertised as being SATA II capable. Can you confirm that you can get SATA III connectivity when using the hot swap bays?
2) The PSU in the case have a 40mm fan, is this fan noisy?
IpNextGen
Hi!
1 : Ive setuped SATA-III Drives in two new boxes i didnt add to the wiki yet.
Here's what's the kernel detected :
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <ST2000VX000-9YW164 CV12> ATA-8 SATA 3.x device
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <ST2000VX000-9YW164 CV12> ATA-8 SATA 3.x device
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada3 at ahcich3 bus 0 scbus3 target 0 lun 0
ada3: <ST2000VX000-9YW164 CV13> ATA-8 SATA 3.x device
ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Soo i assume its SATA 3 Ready and working :)
2) Oh man this box is soo quiet, i plug the fan on the mobo on the "Chassis Fan" .. does speed up if it heat's up.. but never heard anything :)
