On a supermicro dual head storage array that I previously ran Nexenta on, I converted one of the two heads to FreeNAS.. No problem there, everything worked great.
When I converted the second head to FreeNAS, when the second head booted up, instead of going into the new install wizard, it had pulled some of the networking configuration from the first head I updated and had also imported the ZFS pool owned by the first head I had converted.
After shutting down the second head, I tried moving the system dataset on the first head to 'freenas-boot', figuring this would make the second head no longer find this information?
I then performed a new install of the second head, but not instead of booting, it dies into the mountroot> prompt.
All the disks attached to the array are SAS dual ported, so each head can ?unfortunately in this case? see all the other heads volumes.
Thoughts on how to get this to work properly? Perhaps move the boot devices off of hard disks onto USB devices that the other cannot see?
