Migrating boot volume to RAID1?
Blues Guy
Hi, everybody!
I setup my home server (HP Z210, 3,4GHz Xeon, 4C, HT, 16GB ECC-Ram, 4 2TB Samsung 7200rpm SATA-drives in RAIDZ1) with the 9.3 beta and migrated to the 9.3 release.
Looking though the videos, i learned that I can have mirrored boot-volumes now (them being ZFS and all). Does simply exporting the settings, selecting both USB-sticks in the installer and re-importing the configuration work? Is there anything, I have to look out for? Any pitfalls? If I do that, I will use two identical memory-sticks (16GB).
Thank you!
Blues Guy
Thank you very much for your quick and competent answer! I will try that as soon as I get the second memory stick.
