Migrate data, users and all settings except pool and volume names
Terry Wilson
I have a temp Freenas that I setup 4 weeks ago with a newbie volume name and there is not enough storage on this server so I built a beast of a server and installed freenas on it with some better naming conventions. I would love to backup and restore everything on Server A (expect naming conventions) onto Server B, when I say everything I mean everything.... users, all service settings, cron jobs, etc... a complete restore.
What is the best way to do this!
SweetAndLow
Sweet'NASty
Probably best to just set it up with the new names. Most of the configuration is around path and names anyways so you will have to redo all of that stuff anyways.
Terry Wilson
bummer, is there any way to keep server A and swap out the 2TB drives for 6TB drives one at a time (keeping the box up and running) and then in the end the entire volume would be larger?
SweetAndLow
Sweet'NASty
same number of disks? if so then yes you just follow the replace guidelines in the manual. If there are a different number of disks then nope.
Terry Wilson
Well what I was trying to imply is this, Server A has 6 of 2TB drives in the Z1 pool. I was going to try and figure out how to take a drive off line, replace it with a 6TB. let it resilver, then move on to the next 2TB drive in the pool, etc.. rinse and repeat until all were done, then what would be required (if anything) to see the increased capacity in the volume??
Terry Wilson
NAME STATE READ WRITE CKSUM TempReplication ONLINE
raidz1-0 ONLINE
gptid/1a316a9d-7139-11e6-9b12-848f69d9cb8a ONLINE
gptid/1ad2b4b1-7139-11e6-9b12-848f69d9cb8a ONLINE
gptid/1b814639-7139-11e6-9b12-848f69d9cb8a ONLINE
gptid/1c2b3ddc-7139-11e6-9b12-848f69d9cb8a ONLINE
gptid/1cd7c25c-7139-11e6-9b12-848f69d9cb8a ONLINE
spares
da5 AVAIL
So its a Z1 with a spare... Not ideal
You don't need to. You can do the process without first offlining a functioning drive. It's in the manual.
gpsguy
Active Member
We don't recommend RAIDz1 with 6TB drives. If you can back it up somewhere temporarily, I'd rebuild it with all 6 drives in RAIDz2.
depasseg
FreeNAS Replicant
If you want to just rename your datasets (vs changing the structure), do that first on your original server using the GUI. Then take a snapshot, replicate to the new server (keep the same exact root pool name), and then back up the config from the original server and restore on the new one.
Terry Wilson
ok so here is where I stand, built a new server last night with new 6TB drives (6 of them) did a RAIDz2
made a backup of Server A with the gui, then restored that backup to Server B.
So now Server B is "pre-configured" with all the settings of Server A (except IP address, DNS name, etc..) and should be ready to get all the data over. My assumption is I will need to copy this over then go change the paths in usernames for home dir's, and any other reference like CIFS, FTP, etc..?
Terry Wilson
Thanks, I will build a new server and use RAIDZ2 this time.
Terry Wilson
So if I want to migrate all the data from Server A to Server B will this command work?
zfs send -vR TempReplication/Data@auto-20160915.0950-2w | ssh 192.168.111.90
zfs receive -vF Freenas-Beast/storage@auto-20160915.0950-2w
Server A is Source
Server B is destination
Server A Volume is TempReplication and Dataset is Data
Server B Volume is Freenas-Beast and volume is storage
From what I was reading this command will take the snapshot from Server A and send it to Server B where you can then restore the snapshot?
My concerns are obvious , the volume names and dataset names are different so will this even work?
Terry Wilson
or I can just read the manual (duhhh) and implement replication in the Gui
Done..
Now just have to wait until it populates. I see it in storage tab in gui (shows up as Freenas-Beast/storage/Data) but can't traverse to that dir yet from SSH ( I assume I can when it finishes?)
Stux
Did you use recursive replication?
Terry Wilson
Terry Wilson
ok, Replication was the way to go, then we just pointed the users paths to the new dataset and all is well!
