Messed something up with my AFP shares (maybe more things), not quite sure how to fix it.
AMPSandMan
Hello -
So, a little earlier, I was trying to migrate my Plex configuration files from an old warden jail to a new iocage jail. I was copying some files over via command line, accidentally suspended a (non-critical) process, decided to kill it and move on, but made a typo. Instead of kill %1, I entered kill 1, and the web interface became unresponsive shortly thereafter, and I had to hard-reboot my FreeNAS. When it came back up, everything seemed to be working normally, but I can no longer connect to my AFP shares. I can see the NAS in Network, and all of my shares are visible, but when I try to connect to one, I get the message, "The operation can't be completed because the original item for [share] can't be found." Everything is still accessible via command line in the web interface, and my warden-based Plex jail is running just fine. I'm currently running FreeNAS 11.2-U7.
Can anyone help me troubleshoot this? Please let me know what other information you need. Also, explain carefully and slowly - I'm a mechanical engineer that only does this occasionally for my own personal use (i.e. I don't computer especially well, but I can usually figure it out in the end.) Thanks.
Sand
AMPSandMan
Ok, nevermind. After a few days, everything seems to be back to normal. I'll be more careful about checking what I type before I hit enter.
Sand
