jaypetermen
- Apr 1, 2015
I think that I am having permission issues since I can not add the download directories in SABNZBD (it reverts back to is defaults i.e.; /var/db/sabnzbd/Downloads/incomplete ) and I am not modify any files from my Windows 7 pc.
My folder structure is as follows:
plex
plex
jails
media
The Storage permission settings for the following directory plex and it's to childern (jails and media):
dmesg
ifconfig
FreeNAS build:
plex
plex
jails
media
- Apply Owner (user): checked
- Owner (user): root
- Apply Owner (group):checked
- Owner (group): wheel
- Apply Mode: checked
- Mode: all checked but Write > Other
- Permission Type: Unix
- Set permission recursively: checked (while changing permissions)
- Path: /mnt/plex/media
- Use as home share: not checked
- Name: media
- Apply Default Permissions: checked
- Allow Guest Access: checked
dmesg
arp: ac:9e:17: 39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b! arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0 arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b!
ifconfig
Shell
status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x7
ether 02:16:1b:06:72:00
nd6 options=1<PERFORMNUD>
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 9 priority 128 path cost 2000
member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 11 priority 128 path cost 2000
member: epair3a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 12 priority 128 path cost 2000
member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000
member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 20000
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:e0:dd:00:0a:0a
status: active
epair3a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:c8:d2:00:0c:0a
status: active
epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:d6:e0:00:0b:0a
status: active
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:f6:cc:00:09:0a
status: active
[root@freenas ~]#
FreeNAS build:
- FreeNAS-9.3-STABLE-201511280648
- CPU: AMD A6-5400K Trinity Dual-Core 3.6GHz (3.8GHz Turbo)
- Motherboard:ASUS A55BM-PLUS/CSM FM2+ / FM2 AMD A55 (Hudson D2)
- Power Supply:CORSAIR CX series CX500 500W ATX12V v2.3 80 PLUS B
- Ram: G.SKILL Value 24GB 240-Pin DDR3 SDRAM DDR3 1600
- Hard Drive:3x WD Red 3TB NAS Hard Drive: 1 to 8-bay RAID Hard Drive: 3.5-inch SATA 6 Gb/s
- Ethernet
