Media permission and CIFS issue
jaypetermen
I think that I am having permission issues since I can not add the download directories in SABNZBD (it reverts back to is defaults i.e.; /var/db/sabnzbd/Downloads/incomplete ) and I am not modify any files from my Windows 7 pc.
My folder structure is as follows:
plex
plex
jails
media
The Storage permission settings for the following directory plex and it's to childern (jails and media):
  • Apply Owner (user): checked
  • Owner (user): root
  • Apply Owner (group):checked
  • Owner (group): wheel
  • Apply Mode: checked
  • Mode: all checked but Write > Other
  • Permission Type: Unix
  • Set permission recursively: checked (while changing permissions)
CIFS share
  • Path: /mnt/plex/media
  • Use as home share: not checked
  • Name: media
  • Apply Default Permissions: checked
  • Allow Guest Access: checked
dmesg
arp: ac:9e:17:
39:e3:29 is using my IP address 192.168.0.8 on epair2b!
arp: ac:9e:17:39:e3:29 attempts to modify permanent entry for 192.168.0.8 on re0
arp: ac:9e:17:39:e3:29 is using my IP address 192.168.0.8 on epair2b!
ifconfig
Shell
        status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x7
        ether 02:16:1b:06:72:00
        nd6 options=1<PERFORMNUD>
        member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 9 priority 128 path cost 2000
        member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 11 priority 128 path cost 2000
        member: epair3a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 12 priority 128 path cost 2000
        member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 10 priority 128 path cost 2000
        member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 5 priority 128 path cost 20000
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:e0:dd:00:0a:0a
        status: active
epair3a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:c8:d2:00:0c:0a
        status: active
epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:d6:e0:00:0b:0a
        status: active
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:f6:cc:00:09:0a
        status: active
[root@freenas ~]#
FreeNAS build:
  • FreeNAS-9.3-STABLE-201511280648
System hardware:
  • CPU: AMD A6-5400K Trinity Dual-Core 3.6GHz (3.8GHz Turbo)
  • Motherboard:ASUS A55BM-PLUS/CSM FM2+ / FM2 AMD A55 (Hudson D2)
  • Power Supply:CORSAIR CX series CX500 500W ATX12V v2.3 80 PLUS B
  • Ram: G.SKILL Value 24GB 240-Pin DDR3 SDRAM DDR3 1600
  • Hard Drive:3x WD Red 3TB NAS Hard Drive: 1 to 8-bay RAID Hard Drive: 3.5-inch SATA 6 Gb/s
Network:
  • Ethernet
jaypetermen
Looks like the folder structure of my post came was flatted.
  • mnt (actuality called plex)
  • mnt/plex
  • mnt/plex/jails
  • mnt/plex/media
ChiknNutz
I had untold amounts of grief trying to get this sorted out myself. The first thing that comes to mind is, are you sure that you have set up the Jail storage properly?
What I ended up doing when I needed to change a jail storage, right or wrong, was as follows because I found just trying to EDIT them did not produce the desired result and led to odd and undesirable behavior.
  1. Turn off the plug-in
  2. Delete the jail storage
  3. Recreate the jail storage
  4. Turn the plug-in back on
  5. Recreate the appropriate link within the plug-in GUI.
jaypetermen
I have performed 1-4 probably ten time over the last couple days. With different results every time, but always some sort of permissions issue with the plugins.
However, I am not sure what is involved to do #5?
jaypetermen
Today I deleted my Windows Share and changed Storage permission settings for the following directory plex and it's to childern (jails and media):
  • Owner (user): nobody
  • Owner (group): nogroup
  • Permission Type: Windows
The Plex, Couch Potato, and Sonar plugins started okay and I was able to add existing TV series to Sonar.
I can also now delete /media files from Windows 7
The SabNZB plugin would not start, even after restarting it's jail. So I deleted it's storage and then the plug in. I reinstalled it and then added /media as storage. Now it starts.
However, I am still getting the following errer when I try to add /media folders and they dont' take:
ERROR: download_dir directory: /media/downloads/incomplete error accessing
dmesg
Shell
arp: 192.168.0.8 moved from ac:9e:17:39:e3:29 to 02:cb:c6:00:0c:0b on epair1b
epair2a: link state changed to DOWN
epair2b: link state changed to DOWN
epair2a: Ethernet address: 02:75:91:00:0b:0a
epair2b: Ethernet address: 02:75:91:00:0d:0b
epair2a: link state changed to UP
epair2b: link state changed to UP
epair2a: promiscuous mode enabled
ng_ether_ifnet_arrival_event: can't re-name node epair2b
ifa_del_loopback_route: deletion failed
Freed UMA keg (udp_inpcb) was not empty (20 items). Lost 2 pages of memory.
Freed UMA keg (udpcb) was not empty (336 items). Lost 2 pages of memory.
Freed UMA keg (tcptw) was not empty (100 items). Lost 2 pages of memory.
Freed UMA keg (tcp_inpcb) was not empty (30 items). Lost 3 pages of memory.
Freed UMA keg (tcpcb) was not empty (20 items). Lost 5 pages of memory.
Freed UMA keg (ripcb) was not empty (20 items). Lost 2 pages of memory.
hhook_vnet_uninit: hhook_head type=1, id=1 cleanup required
hhook_vnet_uninit: hhook_head type=1, id=0 cleanup required
arp: 192.168.0.6 moved from 02:75:91:00:0b:0a to ac:22:0b:52:10:9a on epair2b
arp: 192.168.0.6 moved from 02:f6:cc:00:09:0a to ac:22:0b:52:10:9a on epair0b
epair2a: Ethernet address: 02:22:62:00:0b:0a
epair2b: Ethernet address: 02:22:62:00:0d:0b
Freed UMA keg (tcpcb) was not empty (16 items). Lost 4 pages of memory.
arp: 192.168.0.6 moved from 02:22:62:00:0b:0a to ac:22:0b:52:10:9a on epair2b
arp: 192.168.0.8 moved from 02:cb:c6:00:0c:0b to ac:9e:17:39:e3:29 on epair1b
[root@freenas ~]#
[root@freenas ~]#
ifconfig
status: active
options=8<VLAN_MTU>
status: active
options=8<VLAN_MTU>
status: active
options=8<VLAN_MTU>
status: active
options=8<VLAN_MTU>
ether 02:22:62:00:0b:0a
status: active
[root@freenas ~]#
SweetAndLow
Sweet'NASty
You should never change the permissions of your root dataset. In this case that means you can't change the permissions of plex dataset. If you want to have something you can share you need to create something like media and use that for sharing and mounting.
