I've noticed slow write speeds and high CPU load from the process "z_wr_iss" while writing larger amounts of data to disk. Testing around a few things I think encryption is to blame.
I created a unencrypted and encrypted dataset, both with lz4 compression and otherwise exactly the same options. I executed
Encrypted Dataset : 2147483648 bytes (2.1 GB, 2.0 GiB) copied, 13.4187 s, 160 MB/s
Unencrypted Dataset : 2147483648 bytes (2.1 GB, 2.0 GiB) copied, 6.64577 s, 323 MB/s
I don't think 160MB/s is the expected maximum I should be getting with this CPU?
I tried to check if AES-NI is enabled using this article : https://www.cyberciti.biz/faq/how-to-find-out-aes-ni-advanced-encryption-enabled-on-linux-system/ but got mixed results. All commands and the values returned :
The command
The command
The command
I watched perf top while executing dd and it this is what it shows :
Do these results mean AES-NI is used or not? If it is used, what could be the bottleneck in my System (Hardware is in Signature). Software Version is TrueNAS-SCALE-22.02.3. If any other Information is required I'll gladly provide any details.
dd if=/dev/random of=./ddtest bs=1M count=2048 oflag=direct on both. The results :Encrypted Dataset : 2147483648 bytes (2.1 GB, 2.0 GiB) copied, 13.4187 s, 160 MB/s
cpuid | grep -i aes | sort | uniq returned :AES instruction = true
VAES instructions = falseThe command
dmesg | grep AES returned nothing.The command
sort -u /proc/crypto | grep module returned :module : aesni_intel+
module : crc32_pclmul
module : crc32c_generic
module : crc32c_intel
module : crct10dif_generic
module : crct10dif_pclmul
module : cryptd
module : essiv
module : ghash_clmulni_intel
module : kernel
The command
openssl engine returned :(rdrand) Intel RDRAND engine
(dynamic) Dynamic engine loading support
23.01% [kernel] [k] gcm_pclmulqdq_mul 10.88% [kernel] [k] kfpu_end 8.47% [kernel] [k] kfpu_begin 7.06% [kernel] [k] chacha_permute 6.49% [kernel] [k] aes_xor_block 5.22% [kernel] [k] aes_encrypt_intel 3.37% [kernel] [k] gcm_mode_encrypt_contiguous_blocks 3.29% [kernel] [k] aes_encrypt_block 2.89% [kernel] [k] aes_aesni_encrypt 2.80% [kernel] [k] aes_copy_block 2.77% [kernel] [k] gcm_mul_pclmulqdq 2.29% [kernel] [k] __x86_retpoline_rax 1.27% [kernel] [k] crypto_get_ptrs 1.16% [kernel] [k] copy_user_enhanced_fast_string 0.74% [kernel] [k] chacha_block_generic 0.63% [kernel] [k] _copy_to_iter
