Making vfs.zfs.arc_max setting persist
Darren David
Hi there-
I've got a new setup with 128GB ram, and I'd like to cap out vfs.zfs.arc_max at around 32GB (I have an 8x10TB RAIDZ2 with ~50TB of usable space). It seems that vfs.zfs.arc_max is set to max RAM - 1GB, and with my rsyncing of data over to this new machine ARC is taking up all the available RAM and causing the entire machine to grind to a halt.
I've tried setting vfs.zfs.arc_max in tunables under both "loader" and "sysctl," and I've also added
vfs.zfs.arc_max="34359738368"
to /boot/loader.conf, but the setting doesn't persist across reboots in any of these scenarios. I can manually set it using sysctl from the command line and all is well, but none of the means I mentioned seem to persist the setting across reboots. I've got 'autotune" disabled, FWIW.
What am I missing here?
Thanks in advance for any and all help.
Chris Moore
What version of FreeNAS are you using?
kdragon75
Chris Moore
Did you install the FreeNAS 11.2-RC2 version of FreeNAS? I have seen several reports today of people having problems with it using all the memory and overflowing swap to the point of total system lockup.
I would suggest going back to the stable version, FreeNAS 11.1-U6, because the RC is a "Release Candidate", not really ready for production.
Darren David
Indeed, I am on 11.2-RC2 (I wanted to play with the newest UI and virtualization tools).
What's interesting is that I have vfs.zfs.arc_max set to 32GB in loader.conf but when the system boots checking the value from the C/L it's showing up at 21GB. Which is certainly less than what is was doing before, as you mentioned, which was using up all available RAM.
Is there a sane way to roll back to stable without losing any data?
