Hello all,
I just upgraded my TrueNAS system from 12.0-U4.1 to 12.0-U6. After the reboot it was terribly slow, opening a folder over SMB takes 4-5 seconds and opening a web app from a jail is almost impossible. GUI is also very slow. Obviously I tried reverting back to the previous boot environment (U4.1) but to my surprise that now has the same problem.
My system is an Intel Xeon E1245v6 on a Supermicro X11SSH-CTF with 64GB of RAM. Boot drives are 2* 128GB SSD's (connected to on-board AHCI SATA controller and running as a mirror) and I have 2 storage pools: 1 consists of 2* 512GB SSD in MIRROR (24% used) and a 6-disk RAIDZ2 with a spare consisting of 8TB WD Red Plus drives. All pools are healthy and all disks are passing LONG smart tests.
I also tried using IPMI and see how local performance is and run some diagnostics, and doing an ls on any directory is taking 2-3 seconds which is not normal. The top command shows 53G of RAM as available, and 95% CPU idle. Starting top also takes a few seconds, which usually goes faster.
Looking at the checks and statistics the system should perform normal. Any hints and clues as to where to look to find the issue is much appreciated.
