zey
- Oct 31, 2014
Hey guys,
Here's my situation. I have a Supermicro X10SDV-TLN4F in a Ablecom CS-M50.
I've been using this setup for some time now. However I'd like to add four more hard drives that I have from an other NAS. I'd like to save the PCI-E slot for a graphics card that I'd like to pass-though to a VM (later project). The X10SDV-TLN4F has six SATA ports leaving me with the need for two more. I won't be using the M.2 slot and would like to use it for four more SATA ports using the following adapter:
SYBA SD-ADA40118 Others M.2 to 4-port SATA III Adapter
2-Lane M.2 PCI-E 2.0 Interface B + M Key
Communication bandwidth up to 10.0 Gbps
Supports Hardware RAID 0, 1, 10
Compliant with Serial ATA Specification 3.0 and communication speed of 6.0 Gbps, 3.0 Gbps and 1.5 Gbps
Hyper Duo mode supports Safe mode (Mirrored Protection) and Capacity mode
Up to 4 SATA devices with point-to-point connectivity
Supports Native Command Queuing (NCQ)
However I am not sure how FreeNAS will communicate through this adapter to the hard drives. I guess my question is has anyone tried doing this?
I'll be upgrading the case to accommodate the additional hard drives. Most likely either the U-NAS NSC-800 or the Silverstone DS380B.
