I setup a new NAS. I mounted it on Windows 10 first, and it went well and everything works. I copied files etc.
I'm now trying to get it going on Ubuntu 20 server. Any time i try to list files in the NAS, I keep getting the error:
I installed nfs-common. After I created a Unix Share (NFS), the mount failed until I enabled NFS and NFSv4. The NFS service is up and running. I tried turning it off/on. I also tried creating a dataset with default options, then put all permissions to 777, and remounted to it.
I used the following variations to mount the NAS:
I tried providing options for username/password when mounting, but that also throws a different error:
Since it works fine on Windows, its an issue with configuring unix/truenas to work. Any ideas?
Version:
TrueNAS-12.0-U1
ls: reading directory 'nas': Input/output error on Ubuntu 20
sudo mount "192.168.1.108:/mnt/pool/dataset" /home/user/nas sudo mount -t nsf "192.168.1.108:/mnt/pool/dataset" /home/user/nas sudo mount -t nsf "192.168.1.108:/mnt/pool" /home/user/nas
sudo mount -t nsf -o username=myUser,password=securePass123 "192.168.1.108:/mnt/pool/dataset" /home/user/nas mount.nfs: an incorrect mount option was specified
Version:
TrueNAS-12.0-U1
