I have 2 issues...
1) I have the SuperMicro 846E1-R900B 24-bay Server Chassis and a SuperMicro X8DTE Motherboard. When I turn it on, it seems to boot fine into FreeDOS (I don't have any drives or OS installed yet) but as soon as it comes on a VERY loud continuous beep goes off and doesn't stop until I turn the machine off. It sounds like it's coming from the backplane, but it's hard to tell for sure. I put my hands over a part of it and it seemed to damped the noise so I'm assuming that's where it's originating from.
2) After turning the system off by holding the power button in for 4 seconds, the system fans shut off, the LEDs all shut off, but the PSU fan keeps running and doesn't stop. I left it plugged in for an hour while off and it ran the entire time. This is my first server, but I can't imagine this is normal operating behavior, is it? If not, what might be causing it?
