Update: This was network related. Not related to FreeNAS.
The problem was, that I was connecting to different NICS on the same FreeNAS machine. The NICS were in different network. When connection via SSH through a firewall, the connection was dropped after ~80 seconds by sshd on the FreeNAS. I have not investigated further. Problem was solved by connection to the FreeNAS NIC in the same network as the client.
Sorry for the noise,
Tobias
Hello forum...
I want to backup some files from my own machine to my FreeNAS machine running Freenas 11..1-U4 (Not latest!).
I can connect with both ssh & sftp. The problem is, that the connection appears to be dropped by the server after around 80-90 seconds. The connection is dropped, even if I'm actively using the session (Moving around, listing etc.). The connection is NOT dropped if I log in as
Here is the content of /usr/local/etc/sshd_config on the FreeNAS machine:
On the client, I have enabled
This is what I see in
Any thoughts on why this is happening much appreciated.
Regards,
Tobias
Tobias
Hello forum...
root. Only my own user is affected.Here is the content of /usr/local/etc/sshd_config on the FreeNAS machine:
cat sshd_config Subsystem sftp /usr/libexec/sftp-server -l ERROR -f AUTH Protocol 2 UseDNS no ChallengeResponseAuthentication no ClientAliveCountMax 3 ClientAliveInterval 15 NoneEnabled yes VersionAddendum none Ciphers +aes128-cbc Port 22 PermitRootLogin without-password AllowTcpForwarding no Compression no PasswordAuthentication yes PubkeyAuthentication yes AllowUsers usera userb root
ServerAliveInterval 10. It looks to me like the client tries to keep the connection alive, as seen here:Code:
time ssh -vvv usera@backup.example.com
OpenSSH_7.2p2 Ubuntu-4ubuntu2.8, OpenSSL 1.0.2g  1 Mar 2016
debug2: channel_input_status_confirm: type 99 id 0
debug2: shell request accepted on channel 0
Last login: Tue Aug  6 17:18:47 2019 from ***
FreeBSD 11.1-STABLE (FreeNAS.amd64) #2 r321665+366f54a78b2(freenas/11.1-stable): Wed Mar 21 23:04:13 UTC 2018
    FreeNAS (c) 2009-2017, The FreeNAS Development Team
    All rights reserved.
    FreeNAS is released under the modified BSD license.
    For more information, documentation, help or support, go here:
     http://freenas.org
Welcome to *****
$ debug3: send packet: type 80
debug3: receive packet: type 82
debug3: receive packet: type 98
debug1: client_input_channel_req: channel 0 rtype keepalive@openssh.com reply 1
debug3: send packet: type 100
debug1: channel 0: free: client-session, nchannels 1
debug3: channel 0: status: The following connections are open:
  #0 client-session (t4 r0 i0/0 o0/0 fd 5/6 cc -1)
Connection to backup.example.com closed by remote host.
Connection to backup.example.com closed.
Transferred: sent 4020, received 3828 bytes, in 80.3 seconds
Bytes per second: sent 50.1, received 47.7
debug1: Exit status -1
real    1m20.574s
user    0m0.032s
sys    0m0.012s
/var/log/auth.log:Code:
Aug 6 17:19:02 *** sshd[99106]: Accepted publickey for *** from CLIENT_IP port 39336 ssh2: RSA SHA256:*** Aug 6 17:19:45 *** sshd[99277]: Connection closed by SERVER_IP port 56091 [preauth] Aug 6 17:20:22 *** sshd[99120]: Timeout, client not responding. Aug 6 17:22:42 *** sshd[265]: Connection closed by SERVER_IP port 56141 [preauth]
Regards,
Tobias
