Login as regular user
qxw
Dear All!
Just a silly question, but I cannot find answer. I can login to webgui as root without any problem.
But if I try login as a rerular user I will get "Please enter a correct Username and password. Note that both fields may be case-sensitive." Username and password should be correct, true ssh (Putty) it works, and also I can acces CIFS shares. Is it normal behaviour of Freenas, or I have something missconfigured?
Thanks.
FreeNAS-9.2.1.7-RELEASE-x64 (fdbe9a0)
enemy85
The webGui can be accessed only from the root user
qxw
Thaks, now it is clear.
This makes sense, right?
WebGUI gives you access to changing virtually all settings in the OS, usernames and passwords, etc.
Standard users shouldn't have access, and you don't want to trust them to not fubar your server. ;)
