I've reported this issue in the past however the developers really blew me off (which kind of pissed me off but whatever).
I ssh into the main freenas installation.
If I try to become root with su and type in root password -- I'm being rejected.
I can become root like this:
I can then go ahead and change root password via passwd command.
Once changing the root password I can then subsequently login with su.
BUT --- if I reboot the system. I'm in the same situation. The password can't even be changed at the boot menu entry (which I refer to as the console) labeled as change root password.
I need to do a sudo su, change password, exit, then a su.
Is this only on my installation? I reported a bug however the people at jira kept asking me what the console was, and didn't understand what I was saying.
freenas% su Password: su: Sorry
freenas% sudo su [root@freenas /mnt/tank/home/kevdog]#
