Tom Johnson
 - Jan 3, 2016
I've played with Freenas for years, probably getting to the point where I'm moderately dangerous.  For many months I've had a problem where my system freezes and become non-responsive.  It doesn't happen quickly after boot, in fact often operating fine for hours - but never 24 hours.  Nor is the freezing aligned with any process that I can discern.
Running FreeNAS 11.3-U3.1
I am running on a SuperMicro H8DM8E-2 motherboard with a SuperMicro BPN-SAS-846TQ backplane.
I have stress tested my memory (60Gig ECC) and my CPU's (duo Six-Core AMD Opteron(tm) Processor 2425 HE (2110.86-MHz K8-class CPU)) a minimum of 12 hours each without failure. I have no SMART reported issues on the 24 hard drives.
I was running three SuperMicro AOC-SAT2-MV8 (not running RAID) but thinking they might be the problem I replaced them with a new IBM ServeRaid M1015 (modified to work in FREENAS) with a IBM 46M0997 16-Port 6GB SAS SATA ServeRAID Expansion Adapter Card - again no RAID. All cabling between the controllers and the hard drives were replaced.
I am running one jail - Plex Media Server.
Finally, I turned on kernel debugging and came up with this report happening about 30s after the end of starting up:
In this instance, nothing more happens until the logfile switched to a new log file at midnight, but when I looked to see if it was running at 7AM, it had frozen.
This seems to be the standard case - I will reboot sometime in the early evening and it runs fine through when I go to bed (before or after midnight), but freezes before I awake.
I can reboot with the IPMI card with no issues every time.
From what I've read abut Lock Order Reversal, it would produce "freezing" like I see. Also, from what I've read, it's probably not a hardware issue but something I'll just need to send in as a bug report.
Any suggestions on further tests I might run to isolate the problem would be helpful. Or better yet, if anyone has a solution would be best of all.
Thank you and awaiting your insightful replies.
Jul 16 21:11:36 freenas lock order reversal: Jul 16 21:11:36 freenas 1st 0xfffff8014b806d50 zfs (zfs) @ /freenas-releng/freenas/_BE/os/sys/kern/vfs_mount.c:908 Jul 16 21:11:36 freenas 2nd 0xfffff80084fa85f0 devfs (devfs) @ /freenas-releng/freenas/_BE/os/sys/kern/vfs_mount.c:919 Jul 16 21:11:36 freenas stack backtrace: Jul 16 21:11:36 freenas #0 0xffffffff80b6fbb0 at witness_debugger+0x70 Jul 16 21:11:36 freenas #1 0xffffffff80b6fa46 at witness_checkorder+0xe76 Jul 16 21:11:36 freenas #2 0xffffffff80ae02a1 at lockmgr_lock_fast_path+0x1b1 Jul 16 21:11:36 freenas #3 0xffffffff811ec8e1 at VOP_LOCK1_APV+0xe1 Jul 16 21:11:36 freenas #4 0xffffffff80be9c97 at _vn_lock+0x67 Jul 16 21:11:36 freenas #5 0xffffffff80bd0c1d at vfs_domount+0xd1d Jul 16 21:11:36 freenas #6 0xffffffff80bcf959 at vfs_donmount+0x7b9 Jul 16 21:11:36 freenas #7 0xffffffff80bcf171 at sys_nmount+0x71 Jul 16 21:11:36 freenas #8 0xffffffff8101b712 at amd64_syscall+0x792 Jul 16 21:11:36 freenas #9 0xffffffff80ff547d at fast_syscall_common+0x101 Jul 16 21:11:37 freenas bridge0: Ethernet address: 02:04:10:24:77:00 Jul 16 21:11:37 freenas kernel: nfe0: promiscuous mode enabled Jul 16 21:11:37 freenas kernel: bridge0: link state changed to UP Jul 16 21:11:37 freenas kernel: bridge0: link state changed to UP Jul 16 21:11:38 freenas epair0a: Ethernet address: 02:ff:10:00:05:0a Jul 16 21:11:38 freenas epair0b: Ethernet address: 02:f1:4f:00:06:0b Jul 16 21:11:38 freenas kernel: epair0a: link state changed to UP Jul 16 21:11:38 freenas kernel: epair0a: link state changed to UP Jul 16 21:11:38 freenas kernel: epair0b: link state changed to UP Jul 16 21:11:38 freenas kernel: epair0b: link state changed to UP Jul 16 21:11:38 freenas kernel: epair0a: changing name to 'vnet0.1' Jul 16 21:11:39 freenas kernel: vnet0.1: promiscuous mode enabled Jul 16 21:11:42 freenas kernel: lo0: link state changed to UP Jul 16 21:11:42 freenas kernel: lo0: link state changed to UP
