I've got an error with deploy_freenas. This is with no certs installed and using http protocol. Issuing a certificate works flawless, it always fails when calling the hook to deploy_freenas:
root@storage:~ # ./deploy_freenas.py
Certificate import successful
Certificate list successful
Setting active certificate successful
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
	chunked=chunked)
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 387, in _make_request
	six.raise_from(e, None)
  File "<string>", line 2, in raise_from
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 383, in _make_request
	httplib_response = conn.getresponse()
  File "/usr/local/lib/python3.6/http/client.py", line 1331, in getresponse
	response.begin()
  File "/usr/local/lib/python3.6/http/client.py", line 297, in begin
	version, status, reason = self._read_status()
  File "/usr/local/lib/python3.6/http/client.py", line 266, in _read_status
	raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
  File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
	timeout=timeout
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
	_stacktrace=sys.exc_info()[2])
  File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 357, in increment
	raise six.reraise(type(error), error, _stacktrace)
  File "/usr/local/lib/python3.6/site-packages/urllib3/packages/six.py", line 685, in reraise
	raise value.with_traceback(tb)
	chunked=chunked)
	response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
  File "./deploy_freenas.py", line 99, in <module>
	auth=(USER, PASSWORD),
  File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 112, in post
	return request('post', url, data=data, json=json, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 58, in request
	return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 502, in request
	resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 612, in send
	r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 490, in send
	raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
When I run it again:
Error importing certificate!
<Response [400]>
I have to change system\general\protocol to http+https and in deploy_freenas I also change the protocol to https. When I run deploy_freenas again it fails with:
  File "/usr/local/lib/python3.6/site-packages/urllib3/contrib/pyopenssl.py", line 441, in wrap_socket
	cnx.do_handshake()
  File "/usr/local/lib/python3.6/site-packages/OpenSSL/SSL.py", line 1426, in do_handshake
	self._raise_ssl_error(self._ssl, result)
  File "/usr/local/lib/python3.6/site-packages/OpenSSL/SSL.py", line 1174, in _raise_ssl_error
	_raise_current_error()
  File "/usr/local/lib/python3.6/site-packages/OpenSSL/_util.py", line 48, in exception_from_error_queue
	raise exception_type(errors)
OpenSSL.SSL.Error: [('SSL routines', 'ssl3_get_server_certificate', 'certificate verify failed')]
	chunked=chunked)
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
	self._validate_conn(conn)
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
	conn.connect()
  File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 326, in connect
	ssl_context=context)
  File "/usr/local/lib/python3.6/site-packages/urllib3/util/ssl_.py", line 329, in ssl_wrap_socket
	return context.wrap_socket(sock, server_hostname=server_hostname)
  File "/usr/local/lib/python3.6/site-packages/urllib3/contrib/pyopenssl.py", line 448, in wrap_socket
	raise ssl.SSLError('bad handshake: %r' % e)
ssl.SSLError: ("bad handshake: Error([('SSL routines', 'ssl3_get_server_certificate', 'certificate verify failed')],)",)
	timeout=timeout
  File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
	raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='storage.hijnn.net', port=443): Max retries exceeded with url: /api/v1.0/system/certificate/import/ (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl3_get_server_certificate', 'certificate verify failed')],)",),))
  File "./deploy_freenas.py", line 45, in <module>
	"cert_privatekey": priv_key,
  File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 504, in send
	raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='storage.hijnn.net', port=443): Max retries exceeded with url: /api/v1.0/system/certificate/import/ (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl3_get_server_certificate', 'certificate verify failed')],)",),))
What am I doing wrong?
