- Aug 16, 2011
The script needs to read the cert and key files. By default, it looks in the directory acme.sh would use for the server's hostname, so in most cases the best thing for you to do would be to update the system hostname through the web GUI to match your FQDN. If you don't want to do that, you can set the cert_fqdn parameter in the config file (so the script will determine the paths using the correct FQDN), and/or the privkey_path and fullchain_path parameters (to tell the cert directly where to find the cert and key files). It's all explained on the github page.
