LDAP Panic from winbindd
JR Gonzalez
I managed to configure LDAP on the FreeNAS box. The users/groups seem to work but something is going wrong with Samba. It almost seems like for whatever reason samba isn't initializing the starttls which ends in a dump. Can somebody point me in the right direction? I've honestly no idea where to even start with this problem. I've attached a .txt of the system log I think relevant.
  • broken_ldap.txt
JR Gonzalez
[global]
server max protocol = SMB3
encrypt passwords = yes
dns proxy = no
strict locking = no
oplocks = yes
deadtime = 15
max log size = 51200
max open files = 11070
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
getwd cache = yes
guest account = nobody
map to guest = Bad User
obey pam restrictions = Yes
directory name cache size = 0
kernel change notify = no
server string = CIFS
ea support = yes
store dos attributes = yes
hostname lookups = yes
acl allow execute always = true
idmap config *:backend = tdb
idmap config *:range = 90000000-100000000
server role = member server
security = user
passdb backend = ldapsam:ldaps://*****************
ldap admin dn = cn=*******,dc=**********,dc=******
ldap suffix = dc=*******,dc=******
ldap user suffix = ou=people
ldap group suffix = ou=groups
ldap ssl = start tls
ldap replication sleep = 1000
ldap passwd sync = yes
ldapsam:trusted = yes
idmap uid = 10000-39999
idmap gid = 10000-39999
netbios name = **********
workgroup = ***********
pid directory = /var/run/samba
smb passwd file = /var/etc/private/smbpasswd
private dir = /var/etc/private
create mask = 0666
directory mask = 0777
client ntlmv2 auth = yes
dos charset = CP437
unix charset = UTF-8
log level = 1
[homes]
comment = Home Directories
valid users = %U
writable = yes
browseable = yes
path = /mnt/platter/home/%U
JR Gonzalez
Found out it was a bug in the smb4.conf generator python script. Guess it's fixed in 9.3. Notsomuch in 9.2. :/ Got past that part. Now i'm having another issue.
