Is there any way to install a knowledge database system accessible from the net on the truenas? And if so which is a good system?
Thank you in advance for yourr help!
You can run any common PHP/Ruby/Python/Java/... web application that does not rely on "Linux only" features in a jail on your TrueNAS. Strictly Linux or Windows applications can run in a virtual machine.
I suggest you google "open source knowledge base system" or some such and pick one or two likely candidates. Then come back for advice on installation.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
