I should have an existing RAIDZ1 pool 3x3tb, but I believe that my key drive may have gone bad, and now I cannot get it to show up on a fresh install of Freenas after the server would not reboot with that drive.
I started receiving errors to my email last week:
They repeated every hour for 29 hours before I attempted to reboot the machine by pressing the power button on the front of the PC assuming it would initiate proper spin down, but this may be my flaw? Would not like to think that. The machine did not boot, the config seemed to be corrupt and threw an error, and now the flash drive just boots to a very genric freenas boot screen that says it cannot boot.
So I did some research, got a new flash drive and installed the same version of freenas. Booted to that, but now cannot find the zpool using the autoimport tool. Nothing on the list. Nothing for zfs import in command line, or any of the variants I could find to try and import it.
I only setup the configuration 2 months ago, and have made the ill fated mistake of not having a proper backup yet, as I was finishing up the process of migrating things TOO it, and severely underestimated the power of data loss, even while trying to mitigate that very problem. Which is irony I suppose. but mostly stupidity.
I found an old topic that asked for a gpart show, which does show all three drives.
At this point I'm at a loss, and I'm just not sure why they don't appear, and just suddenly dropped off the planet yet the data still exists! I am at a wall, so I'm desperately asking for some guidance.
Cron <root@AmpEnergy> /bin/sh /root/save_rrds.sh Segmentation fault (core dumped)
[root@freenas ~]# gpart show
=> 34 5860533101 ada0 GPT (2.7T)
34 94 - free - (47k)
128 4194304 1 freebsd-swap (2.0G)
4194432 5856338696 2 freebsd-zfs (2.7T)
5860533128 7 - free - (3.5k)
=> 34 5860533101 ada1 GPT (2.7T)
=> 34 5860533101 ada2 GPT (2.7T)
=> 63 15633345 da0 MBR (7.5G)
63 1930257 1 freebsd [active] (942M)
1930320 63 - free - (31k)
1930383 1930257 2 freebsd (942M)
3860640 3024 3 freebsd (1.5M)
3863664 41328 4 freebsd (20M)
3904992 11728416 - free - (5.6G)
=> 0 1930257 da0s1 BSD (942M)
0 16 - free - (8.0k)
16 1930241 1 !0 (942M) At this point I'm at a loss, and I'm just not sure why they don't appear, and just suddenly dropped off the planet yet the data still exists! I am at a wall, so I'm desperately asking for some guidance.
