therealego
- Dec 1, 2022
As the title suggests, I am getting the above error message when trying to boot (from either boot device).
Not really sure what could have caused this, it happened right after a BIOS update but as far as I'm aware a BIOS update shouldn't break my OS.
To be completely honest, I'm not overly worried about simply reinstalling and reconfiguring all my apps, but I don't want to lose all my data.
If I can somehow wipe the boot drives and just reinstall, then get the data off the drives afterwards then I will totally do that; however it is my understanding that you must export your pool before you can reimport it in another system/install.
Here are my system specs:
- TrueNAS Scale OS
- Core i3 12100
- Asrock z690 Extreme
- 128GB G.Skill Ripjaws X DDR4 3200
- 2x 32GB Intel M10 Optane memory modules for mirrored boot drive
- 2x 1TB WD Black SN850x for striped L2ARC
- 8x 1TB SATA HDD for storage pool
- TrueNAS Scale OS
- Core i3 12100
