kernalzero
- Apr 26, 2018
Error getting pool data.
JSON.parse: unexpected end of data at line 1 column 1 of the JSON data
Hey,
I don't post often but I recently upgraded to 11.3 and can't find any information about this issue. Since upgrading I've actually had to reinstall once which was disturbing as I'd been up and running with each new version of 11 since it was released without issue. I started seeing the error above when I went to add a zvol and can't. This was the first time I've gone in to do anything in the pools menu since upgrading. Any suggestions or help is appreciated. System details below.
I'm running:
FreeNAS-11.3-U1 (upgraded from 11.2-U6) on
SuperMicro X11SSM-F | Intel E3-1240 v6 3.7Ghz | 32GB ECC DDR4 | Boot: Dual PNY 120GB SSD (mirrored) | Pool: 6x4 TB RAIDZ2 WD Red
Error: sE5F/y</t.prototype.json@http://10.0.1.10/ui/main.06051265c80c8491735f.js:1:3305877 tnAE/s</t.prototype.handleError@http://10.0.1.10/ui/main.06051265c80c8491735f.js:1:3428532 9Z1F/u</e.prototype.error@http://10.0.1.10/ui/main.06051265c80c8491735f.js:1:341973 FFOo/c</e.prototype._error@http://10.0.1.10/ui/main.06051265c80c8491735f.js:1:803391 FFOo/c</e.prototype.error@http://10.0.1.10/ui/main.06051265c80c8491735f.js:1:803085 l@http://10.0.1.10/ui/main.06051265c80c8491735f.js:1:3308050 r/</l</e.prototype.invokeTask@http://10.0.1.10/ui/polyfills.9a59520395d052abd25e.js:1:16894 onInvokeTask@http://10.0.1.10/ui/main.06051265c80c8491735f.js:1:610000 r/</l</e.prototype.invokeTask@http://10.0.1.10/ui/polyfills.9a59520395d052abd25e.js:1:16815 r/</c</t.prototype.runTask@http://10.0.1.10/ui/polyfills.9a59520395d052abd25e.js:1:11973 r/</f</t.invokeTask@http://10.0.1.10/ui/polyfills.9a59520395d052abd25e.js:1:18026 p@http://10.0.1.10/ui/polyfills.9a59520395d052abd25e.js:1:31038 h@http://10.0.1.10/ui/polyfills.9a59520395d052abd25e.js:1:31345
Hey,
I'm running:
