JBOD Raid possible with FreeNAS?
max1zzz
Is it possible to set up my drives in a JBOD array with FreeNAS, i need to use multiple drive sizes, and don't need any of the redundancy features of the other raids (as the dive will be backed up every 12hours)
Thanks
max1zzz
ok, i solved the problem myself, turns out you can't do JBOD in FreeNAS 8.0.2, however, you can in FreeNAS 0.7.2, so I'm using that for the time being, and i must say I'm very impressed so far, tommrow this will replace my single failing disk in my server.
