Jail VNET routed Ipv6 only problems
billias
Hi All,
I have a fresh Freenas setup, which I am now migrating all my LXC containers (from an ubuntu) to Jails. Everything runs smoothly. Especially the transition from Linux to BSD. Except the ipv6 (and only when routed to outside world) which has heavy packet loss. I pinned it only on jails with VNET use.
My system:
AsRock H370M-ITX, i5-8400, 32Gbytes ram, 4*4TB WD Red. Freenas 11.2U2.1
I do have two ethernet controllers on the System. em0 (connected on VLAN1) and igb0 (connected on DMZ Vlan5).
It is not limited to ping, but with ping we can see the packet loss:
root@ns2:/ # ping6 google.com
PING6(56=40+8+8 bytes) 2a*******:6eee::3 --> 2a00:1450:400e:80d::200e
16 bytes from 2a00:1450:400e:80d::200e, icmp_seq=14 hlim=57 time=837.461 ms
16 bytes from 2a00:1450:400e:80d::200e, icmp_seq=15 hlim=57 time=1.426 ms
16 bytes from 2a00:1450:400e:80d::200e, icmp_seq=16 hlim=57 time=1.416 ms
16 bytes from 2a00:1450:400e:80d::200e, icmp_seq=17 hlim=57 time=1.368 ms
16 bytes from 2a00:1450:400e:80d::200e, icmp_seq=18 hlim=57 time=1.547 ms
16 bytes from 2a00:1450:400e:80d::200e, icmp_seq=19 hlim=57 time=1.425 ms
16 bytes from 2a00:1450:400e:80d::200e, icmp_seq=20 hlim=57 time=1.607 ms
16 bytes from 2a00:1450:400e:80d::200e, icmp_seq=21 hlim=57 time=1.484 ms
16 bytes from 2a00:1450:400e:80d::200e, icmp_seq=22 hlim=57 time=1.489 ms
^C
--- google.com ping6 statistics ---
26 packets transmitted, 9 packets received, 65.4% packet loss
round-trip min/avg/max/std-dev = 1.368/94.358/837.461/262.727 ms
root@ns2:/ #
From Jane (the server):
    ether 02:5f:2f:c2:59:00
    groups: bridge
    member: vnet0:6 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 10 priority 128 path cost 2000
    member: vnet0:5 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 9 priority 128 path cost 2000
    member: vnet0:4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 7 priority 128 path cost 2000
    member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 1 priority 128 path cost 55
root@jane[~]# ifconfig igb0
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
    ether 70:85:c2:7b:b9:35
    hwaddr 70:85:c2:7b:b9:35
    media: Ethernet autoselect (1000baseT <full-duplex>)
    status: active
Also some em0 info:
root@jane[~]# ifconfig em0
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=2098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
    ether 70:85:c2:7b:b9:33
    hwaddr 70:85:c2:7b:b9:33
    inet 10.10.0.200 netmask 0xfffffc00 broadcast 10.10.3.255
    inet 10.10.0.131 netmask 0xfffffc00 broadcast 10.10.3.255
    inet 10.10.0.202 netmask 0xfffffc00 broadcast 10.10.3.255
    inet 10.10.0.20 netmask 0xfffffc00 broadcast 10.10.3.255
    inet6 fe80::7285:c2ff:fe7b:b933%em0 prefixlen 64 scopeid 0x2
    inet6 2******:6eee::cfc prefixlen 64
    inet6 2******:6eee::d prefixlen 64
    status: active
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    ether 02:5f:2f:c2:59:01
    groups: bridge
    member: vnet1:5 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 8 priority 128 path cost 2000
    member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 2 priority 128 path cost 55
I do not have any other Ipv6 problems but with VNET devices only. This lead to suspect some setting in the system which might be causing this
One of the jails which has the problems:
root@jane[~]# iocage get all ns2
CONFIG_VERSION:14.1
allow_chflags:0
allow_mlock:0
allow_mount:0
allow_mount_devfs:0
allow_mount_nullfs:0
allow_mount_procfs:0
allow_mount_tmpfs:0
allow_mount_zfs:0
allow_quotas:0
allow_raw_sockets:1
allow_set_hostname:1
allow_socket_af:1
allow_sysvipc:0
allow_tun:0
available:readonly
basejail:no
boot:on
bpf:yes
children_max:0
cloned_release:11.2-RELEASE
comment:none
compression:lz4
compressratio:readonly
coredumpsize:off
count:1
cpuset:off
cputime:off
datasize:off
dedup:off
defaultrouter:10.10.0.1
defaultrouter6:2********:6eee::1
depends:none
devfs_ruleset:4
dhcp:off
enforce_statfs:2
exec_clean:1
exec_fib:0
exec_jail_user:root
exec_poststart:/usr/bin/true
exec_poststop:/usr/bin/true
exec_prestart:/usr/bin/true
exec_prestop:/usr/bin/true
exec_start:/bin/sh /etc/rc
exec_stop:/bin/sh /etc/rc.shutdown
exec_system_jail_user:0
exec_system_user:root
exec_timeout:60
host_domainname:lan.billias.cc
host_hostname:ns2
host_hostuuid:ns2
host_time:yes
hostid:246d7f05-3808-11e9-9a5c-bc5ff4976051
hostid_strict_check:no
interfaces:vnet1:bridge1,vnet0:bridge0
ip4:new
ip4_addr:vnet0|10.10.5.3/24,vnet1|10.10.0.3/22
ip4_saddrsel:0
ip6:new
ip6_addr:vnet1|2******:6eee::3/64,vnet0|2*******05::3/64
ip6_saddrsel:0
jail_zfs:off
jail_zfs_dataset:iocage/jails/ns2/data
jail_zfs_mountpoint:none
last_started:2019-03-04 06:03:27
login_flags:-f root
mac_prefix:bc5ff4
maxproc:off
memorylocked:off
memoryuse:off
mount_devfs:1
mount_fdescfs:1
mount_linprocfs:0
mount_procfs:0
mountpoint:readonly
msgqqueued:off
msgqsize:off
nmsgq:off
notes:none
nsemop:off
nshm:off
nthr:off
openfiles:off
origin:readonly
owner:root
pcpu:off
priority:110
pseudoterminals:off
quota:none
release:11.2-RELEASE-p9
reservation:none
resolver:/etc/resolv.conf
rlimits:off
securelevel:2
shmsize:off
stacksize:off
state:up
stop_timeout:30
swapuse:off
sync_state:none
sync_target:none
sync_tgt_zpool:none
sysvmsg:new
sysvsem:new
sysvshm:new
template:no
type:jail
used:readonly
vmemoryuse:off
vnet:on
vnet0_mac:bc5ff4552455 bc5ff4552456
vnet1_mac:bc5ff4552457 bc5ff4552458
vnet2_mac:none
vnet3_mac:none
vnet_default_interface:em0
vnet_interfaces:none
wallclock:off
root@jane[~]#
Tried both allow_socket_af 0/1
I did also try some sysctl settings found around internet (while searching)
Turned of STP on my switch too.
Also when I start pinging from my Router! the IPv6 of the Jail (vnet jail) network becomes stable for the jail!
Thanks
billias
nope, I installed an ubuntu hyve with lcx and works. Planning to move back to ubuntu as freenas is fantastic but hardware is not in most cases compatible
(usb3 probs, ipv6 on vnets etc)
