Jailer
Not strong, but bad
- Sep 12, 2014
Been working for this for a while today now without any success. When running
Here's the console output and where it ends.
I let it sit like this for a few hours and it doesn't continue. The console just shows (END) and will do nothing until I abort the process by hitting Ctrl+C. This is very concerning as I have 14 jails running and I REALLY don't want to have to rebuild all my jails from scratch. I can't post at the FreeBSD forums since it's FreeNAS and they'll punt you over to this forum as soon as they know it's not FreeBSD you're working on.
Anybody got any idea what's going on with this?
iocage upgrade qbittorrent1 -r 12.2-RELEASE
the upgrade process starts but ends up stalling out and doesn't complete. I've checked the iocage github page to see if anyone else has reported a similar issue and I couldn't find anything there. I know other users have reported issues with upgrading their jails but none that I could find have reported the issue I'm having. I also checked the iocage log and there's nothing it regarding this.Here's the console output and where it ends.
root@freenas:~ # iocage upgrade qbittorrent1 -r 12.2-RELEASE Looking up update.FreeBSD.org mirrors... 3 mirrors found. Fetching metadata signature for 11.4-RELEASE from update1.freebsd.org... done. Fetching metadata index... done. Fetching 1 metadata patches. done. Applying metadata patches... done. Fetching 1 metadata files... done. Inspecting system... done. The following components of FreeBSD seem to be installed: src/src world/base world/doc world/lib32 The following components of FreeBSD do not seem to be installed: world/base-dbg world/lib32-dbg Does this look reasonable (y/n)? y Fetching metadata signature for 12.2-RELEASE from update1.freebsd.org... done. Fetching metadata index... done. Fetching 1 metadata patches. done. Applying metadata patches... done. Fetching 1 metadata files... done. Inspecting system... done. Fetching files from 11.4-RELEASE for merging... done. Preparing to download files... done. Attempting to automatically merge changes in files... done. The following changes, which occurred between FreeBSD 11.4-RELEASE and FreeBSD 12.2-RELEASE have been merged into /etc/group: --- current version +++ new version @@ -1,6 +1,6 @@ -# $FreeBSD: releng/11.4/etc/group 359448 2020-03-30 17:11:21Z brooks $ +# $FreeBSD: releng/12.2/etc/group 359447 2020-03-30 17:07:05Z brooks $ # wheel:*:0:root daemon:*:1: kmem:*:2: sys:*:3: @@ -27,10 +27,11 @@ uucp:*:66: dialer:*:68: network:*:69: audit:*:77: www:*:80: +ntpd:*:123: _ypldap:*:160: hast:*:845: tests:*:977: nogroup:*:65533: nobody:*:65534: Does this look reasonable (y/n)? y The following changes, which occurred between FreeBSD 11.4-RELEASE and FreeBSD 12.2-RELEASE have been merged into /etc/master.passwd: --- current version +++ new version @@ -1,6 +1,6 @@ -# $FreeBSD: releng/11.4/etc/master.passwd 359448 2020-03-30 17:11:21Z brooks $ +# $FreeBSD: releng/12.2/etc/master.passwd 359447 2020-03-30 17:07:05Z brooks $ # root::0:0::0:0:Charlie &:/root:/bin/csh toor:*:0:0::0:0:Bourne-again Superuser:/root: daemon:*:1:1::0:0:Owner of many system processes:/root:/usr/sbin/nologin operator:*:2:5::0:0:System &:/:/usr/sbin/nologin @@ -20,10 +20,11 @@ _dhcp:*:65:65::0:0:dhcp programs:/var/empty:/usr/sbin/nologin uucp:*:66:66::0:0:UUCP pseudo-user:/var/spool/uucppublic:/usr/local/libexec/uucp/uucico pop:*:68:6::0:0:Post Office Owner:/nonexistent:/usr/sbin/nologin auditdistd:*:78:77::0:0:Auditdistd unprivileged user:/var/empty:/usr/sbin/nologin www:*:80:80::0:0:World Wide Web Owner:/nonexistent:/usr/sbin/nologin +ntpd:*:123:123::0:0:NTP Daemon:/var/db/ntp:/usr/sbin/nologin _ypldap:*:160:160::0:0:YP LDAP unprivileged user:/var/empty:/usr/sbin/nologin hast:*:845:845::0:0:HAST unprivileged user:/var/empty:/usr/sbin/nologin tests:*:977:977::0:0:Unprivileged user for tests:/nonexistent:/usr/sbin/nologin nobody:*:65534:65534::0:0:Unprivileged user:/nonexistent:/usr/sbin/nologin messagebus:*:556:556::0:0:D-BUS Daemon User:/nonexistent:/usr/sbin/nologin Does this look reasonable (y/n)? y The following changes, which occurred between FreeBSD 11.4-RELEASE and FreeBSD 12.2-RELEASE have been merged into /etc/passwd: --- current version +++ new version @@ -1,6 +1,6 @@ -# $FreeBSD: releng/11.4/etc/master.passwd 359448 2020-03-30 17:11:21Z brooks $ +# $FreeBSD: releng/12.2/etc/master.passwd 359447 2020-03-30 17:07:05Z brooks $ # root:*:0:0:Charlie &:/root:/bin/csh toor:*:0:0:Bourne-again Superuser:/root: daemon:*:1:1:Owner of many system processes:/root:/usr/sbin/nologin operator:*:2:5:System &:/:/usr/sbin/nologin @@ -20,10 +20,11 @@ _dhcp:*:65:65:dhcp programs:/var/empty:/usr/sbin/nologin uucp:*:66:66:UUCP pseudo-user:/var/spool/uucppublic:/usr/local/libexec/uucp/uucico pop:*:68:6:Post Office Owner:/nonexistent:/usr/sbin/nologin auditdistd:*:78:77:Auditdistd unprivileged user:/var/empty:/usr/sbin/nologin www:*:80:80:World Wide Web Owner:/nonexistent:/usr/sbin/nologin +ntpd:*:123:123:NTP Daemon:/var/db/ntp:/usr/sbin/nologin _ypldap:*:160:160:YP LDAP unprivileged user:/var/empty:/usr/sbin/nologin hast:*:845:845:HAST unprivileged user:/var/empty:/usr/sbin/nologin tests:*:977:977:Unprivileged user for tests:/nonexistent:/usr/sbin/nologin nobody:*:65534:65534:Unprivileged user:/nonexistent:/usr/sbin/nologin messagebus:*:556:556:D-BUS Daemon User:/nonexistent:/usr/sbin/nologin Does this look reasonable (y/n)? y The following files are affected by updates. No changes have been downloaded, however, because the files have been modified locally: /etc/ssl/certs/cd8c0d63.0 (END)
