Jail network settings kernel panic
DaAwesomeP
Hello!
I am getting kernel panics when I start and stop jails, usually after adjusting network settings. They seem to work when I just set them to DHCP, but they don't work when I set a static IP. I am only configuring using the web UI. I have tried with and without VNETs. What am I doing wrong? I am trying to install the Emby jail and set it to use a static IP on a different interface instead of a DHCP IP in the default interface.
I would provide logs, but the panics appear on the console screen very briefly before the machine restarts. It might restart once or twice until it settles and then I can get to the UI again. Let me know what other info I should provide.
Up to date FreeNAS 11.3-U4.
Thanks!
DaAwesomeP
OK I'm going to reinstall. I got it to crash by restarting the SMB service. I ran a full memtest and it came out fine.
DaAwesomeP
OK, so the kernel panics are page faults. Just to be sure its not the RAM, I took out half the RAM and then I got this error instead:
Panic String: free: address 0xffffffff81a7ab70(0xffffffff81a7a000) has not been allocated.
Again, this passed memtest, so I'm really not sure what is going on.
DaAwesomeP
OK, swapped the memory again and got this:
Panic String: solaris assert: illumos_nvlist_add_nvlist(nvl, name, val) == 0 (0x16 == 0x0), file: /freenas-releng/freenas/_BE/os/sys/cddl/contrib/opensolaris/common/nvpair/opensolaris_fnvpair.c, line: 20
