MasterTacoChief
- Feb 20, 2017
I have installed a Emulex P005414 dual-10G card, and am currently using port 0 which is oce0 in the OS:
This interface works great as a connection to FreeNAS via SMB and NFS. The web interface works fine as well. What is strange is that any jail that is bridged with this connection seems to not have a connection between this interface and itself. Inside the jail I can't ping anything, and I also can't reach anything inside the jail from my LAN (in this case qBittorrent on port 8080).
I also have a LACP LAGG (lagg0) composed of two 1GB ethernet ports (bge0 and bge1). When the bridge contains this interface instead of the oce0 interface then the jail can access the network with no problem at all.
FreeNAS seems to create a bridge out of the "first" interface. To define the "first" interface I had to destroy all network interfaces, configure lagg0, then configure oce0. Then the jail has a bridge with lagg0. Great, except as soon as I rebooted it somehow decided oce0 should be in the bridge instead.
So a few questions:
- Why doesn't bridging work with the Emulex card? I've seen in a few other (older) posts that Emulex might not work so well with everything, so if that's the answer then I can live with that. It works fine for my primary use (10G external access).
- I'm fine with creating a bridge using lagg0, but how do I tell FreeNAS to always use lagg0 to create the bridge and NOT oce0?
This might be an obvious thing for a seasoned FreeBSD user, but I'm fairly new to this OS. Thanks for the help.
[root@nas ~]# ifconfig oce0 oce0: flags=8143<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> metric 0 mtu 1500 options=500b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_ HWFILTER,VLAN_HWTSO> ether 00:90:fa:79:87:1a inet 192.168.1.35 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (10Gbase-SR <full-duplex>) status: active
So a few questions:
