Issue with plugins since 9.1 upgrade
DiscoDave
Hi everyone,
SABNZBD is encountering permission issues since I performed an upgrade to 9,1 (
(Cannot create final folder )
Current user/group permissions set to my folders are 40001 40001. But just to clarify, can someone please tell me what *should* be the correct permissions for SABNZBD folders (inside/outside of jails) and which accounts these should be?
Thanks,
D
dlavigne
Guest
What version did you upgrade from? When does the error occur?
The files need to be owned by the sabnzbd user and sabnzbd group.
