Hi
I configured TrueNAS-SCALE-21.06-BETA.1 to connect to my active directory when it came out (brand new install) and everything worked fine.
In the meantime, I went through a rename of the AD. Windows stations are working fine, but TrueNas scale still has some references to the old name in the UI (Kerberos Principal for example) and can't connect to the new AD name.
Are there some config files I can remove to reset AD config? (I'd like to avoid reinstalling everything from scratch)
Thanks
Thanks
