boggie1688
- Jul 9, 2015
First and foremost I'm a Plex noobie, so please be patient with me.
I installed the Plex plugin.
I assigned the mount points:
/mnt/XXXXX/Movies -> /plexmediaserver/media/Movies
/mnt/XXXXX/TvShows -> /plexmediaserver/media/TvShows
Using the Plex web based GUI, I create a Library folder for movies, then point it at /plexmediaserver/media/Movies. Everything works as expected and Plex promptly imports the movies.
The problem comes when I try to do the same for TvShows. Under the GUI where I add the folder, the icon next to TvShows is not a folder but a file. I'm not sure what is going on here. The mount points are used by my the Freenas SMB share so I can access these files via my desktop, and there are no issues.
Any idea what is going on here?
