I was wondering if I’d missed something?
(just to get that out of the way: no data loss or anything)
System 1: X9SCM with xeon 1220Lv2 and 16GB of RAM; 6X4TB in RAIDz2 encrypted, running FreeNAS 9.10.2.
I have a backup of the configuration and of the key file.
I migrated the disks to an other system.
System 2: HP DL380 G6 with 2 xeon L5640, 208GB of RAM, LSI HBA, running VMware.
I created a VM for FreeNAS with 64GB dedicated RAM and the LSI HBA passed through and installed FreeNAS 9.10.2.
I used the same version on the new system to import the config file (so I don’t have to reconfigure the shares, user, tasks and so on, nothing very fancy though).
I installed FreeNAS, the disks were showing up, no problem.
- I imported the configuration without any problem. Then I imported the volume.
The volume was found then I entered the passphrase and the key file but then it wouldn’t decrypt the disks (I didn’t write down the error :-( but it was a message saying that the disk could not be decrypted).
- I tried the other way around with the volume import first. There I did’t have any problem (I entered the passphrase and the key file and the volume got decrypted).
Afterwards, I couldn’t import the configuration file (but I don’t recall why exactly... how annoying when you realize afterwards you’re missing parts...) that’s why I had to do the configuration manually, which was a bit time consuming but nothing complicated.
So my question is: does anyone observed this behavior? And is this behavior to be expected? Or did I miss something (what?)?
I know encrypted pools are not very popular... :-D But why didn’t the configuration file worked properly (well it worked but it prevented me to decrypt the volume)?
To that I have a possible thought:
- I would assume the configuration is hardware independent... but maybe not or not completely or not compatible with FreeNAS runnning in a VM (and importing the config from bare metal)?
Thank you for your feedback!
