SOLVED Issue getting jail releases
joncy92
Hi All,
I'm brand new to both FreeBSD and FreeNAS and most of the concepts are pretty alien to me. With that said I'm fairly tech savvy and I'm picking stuff up well.
I just have a couple of questions as I want to ensure I've understood things correctly and I'm facing an issue creating jails.
I have repurposed a Dell T130 server to run freenas. The build is:
Intel(R) Pentium(R) CPU G4500 @ 3.50GHz (2 cores)
16GiB RAM
2xGb LOM controllers (I believe it's a broadcom chipset)
Dell H730 RAID controller
32GiB internal USB stick with FreeNAS installation
2x WD Red 6TB
2x 2TB (i don't know what disks they are)
I have successfully installed FreeNAS and created 1 zpool with a dataset.
Currently the zpool has 1 vdev which contains 1 WD Red. The other disk is currenly sitting in my very old Synology NAS in degraded RAID so I can migrate my data accross.
Once I've migrated the data, can I add the remaining disk into the current vdev and create a mirror?
Can I then extend the pool to have another vdev which will contain the 2x2TB disks in mirror? (I've seen this questions asked and answered a lot on the forum and I keep finding conflicting answers).
Onto the jails:
I'm trying to create a jail in the current zpool, but I am getting the following error message:
[SIZE=7][B] Error: Fetching remote release choices failed.[/B][/SIZE] ('Connection aborted.', ConnectionResetError(54, 'Connection reset by peer'))
Error: concurrent.futures.process._RemoteTraceback:
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
    chunked=chunked)
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 387, in _make_request
    six.raise_from(e, None)
  File "<string>", line 2, in raise_from
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 383, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/local/lib/python3.6/http/client.py", line 1331, in getresponse
    response.begin()
  File "/usr/local/lib/python3.6/http/client.py", line 297, in begin
    version, status, reason = self._read_status()
  File "/usr/local/lib/python3.6/http/client.py", line 258, in _read_status
    line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
  File "/usr/local/lib/python3.6/socket.py", line 586, in readinto
    return self._sock.recv_into(b)
ConnectionResetError: [Errno 54] Connection reset by peer
  File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
    timeout=timeout
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 357, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/usr/local/lib/python3.6/site-packages/urllib3/packages/six.py", line 685, in reraise
    raise value.with_traceback(tb)
    chunked=chunked)
    response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(54, 'Connection reset by peer'))
  File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
    r = call_item.fn(*call_item.args, **call_item.kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 133, in main_worker
    res = loop.run_until_complete(coro)
  File "/usr/local/lib/python3.6/asyncio/base_events.py", line 484, in run_until_complete
    return future.result()
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 93, in _run
    return await self._call(name, serviceobj, methodobj, params=args, job=job)
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 85, in _call
    return methodobj(*params)
  File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
    return f(*args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 592, in list_resource
    resource_list = iocage.fetch(list=True, remote=remote, http=True)
  File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 961, in fetch
    _list=True)
  File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_fetch.py", line 232, in fetch_release
    rel = self.fetch_http_release(eol, _list=_list)
  File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_fetch.py", line 428, in fetch_http_release
    req = requests.get(f"{self.server}/{self.root_dir}")
  File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 72, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 490, in send
    raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(54, 'Connection reset by peer'))
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 165, in call_method
    result = await self.middleware.call_method(self, message)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1107, in call_method
    return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1052, in _call
    return await self._call_worker(name, *args)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1072, in _call_worker
    return await self.run_in_proc(main_worker, name, args, job)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 995, in run_in_proc
    return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 971, in run_in_executor
I am able to ping download.freenas.org from the shell.
Any help is greatly appreciated. Thanks!
Seems like a connectivity issue. I had the same thing happen with a couple of plugins on the repository side.
That said, when you ssh into your FreeNAS server can you ping the download.freenas.org? What about Google's DNS (8.8.8.8 or 8.8.4.4)?
joncy92
Hi mate thanks for the reply.
Aye I've already tried pinging google and download.freenas.org (I mentioned in the bottom of my original post).
I've tried setting the name servers to both google and my router and I have the same issue =[
Andy C
I had this problem (creating jails from the GUI) this morning which has since disappeared. I was able to manually create jails from the command-line using iocage.
Are you able to browse...?
joncy92
Hi Andy...I never actually thought to try browsing to it from another machine.
I can ping the site but I cannot browse to it.
Chrome shows ERR_CONNECTION_RESET or ERR_CONNECTION_CLOSED.
I get this from my home internet or mobile internet.
joncy92
^ Sorry for double post...I can't see how to edit a post.
I am able to browse and ping download.freenas.org
I am able to ping but not browse download.freebsd.org
Anyone can advise how to get the jail up?
Thanks
Thadah
I'm having the same issue when trying to install plugins or creating a new jail.
Trying to access download.freebsd.org will return PR_CONNECT_RESET_ERROR in Firefox. This happens when I'm using my home network and mobile data as well.
Like @joncy92 I'm able to browse and ping download.freenas.org but I can only ping download.freebsd.org
MarvinWright
Same problem here. Looks like its a problem with my ISP though, If I connect to my works VPN I can then access download.FreeBSD.org.
Is there a way to configure the OS to go to a mirror server ?
joncy92
Here is what I get when trying to connect to download.freebsd.org:
FreeBSD.org download server
This is download.FreeBSD.org - an east coast US regional mirror for FreeBSD downloads.
It is generously hosted by NYI - New York Internet in New Jersey, USA.
This server's contents:
FreeBSD.org home
You might be able to use a mirror...
Hi. I've been able to browse using a mirror. I'm not sure why I can't connect to the primary URL from here (London)
I've tried overriding DNS at the router level but because the mirrors have a different folder structure, the FreeNAS GUI connects to the mirror but then cannot find the releases folder.
I have a VPN that I can use - is it possible to configure FreeNAS to use a VPN system-wide so that the jail releases can be updated/loaded. The VPN can then be disabled. I've googled around for an answer but all posts just mention that VPN should be configured inside a Jail....which I cannot create lol.
Also just a side note, if I run
pkg update
in putty SSH, I get this error:
Updating local repository catalogue...
pkg: Repository local load error: access repo file(/var/db/pkg/repo-local.sqlite) failed: No such file or directory
pkg: file:///usr/ports/packages/meta.txz: No such file or directory
repository local has no meta file, using default settings
pkg: file:///usr/ports/packages/packagesite.txz: No such file or directory
Unable to update repository local
Error updating repositories!
joncy92
FreeBSD.org home
pkg update
joncy92
Okay I've made a little progress... judging by the other posts, it seems UK ISPs will not connect to the freebsd download site.
I registered to SecurityKISS VPN for a free account and configured my DD-WRT router to use the service. I was then able to browse to download.freebsd.org
I fired up the FreeNAS and tried to create jail, when I looked for releases I was able to pick between 11.2 and 11.3.
When I tried 11.3 it saod fetching 50% and didn't move.
I got impatient, refreshed and tried 11.2.
Then I just sat on creating jail and did nothing more.
I've given up now and will try more over the weekend.
Is there anyway to view logs for jail creation? Anyone have any ideas to why it kept getting stuck?
Hazimil
Hi All, I'm also getting this issue. Using v11.2-U7 and UK based, using Sky as my ISP. I am unable to connect to https://download.freebsd.org/ via my PC (as a test), but if I use a VPN (NordVPN) to connect to USA I can connect to the site.
I have tried using my VPN to connect to UK (so different path) and still no connection, the same with using Norway but France and Spain connect! Weird.
From my FreeNAS box, I'm getting the following error with iocage fetch:
root@fruitbowl:~ # iocage fetch
    chunked=chunked)
    response.begin()
    timeout=timeout
    chunked=chunked)
    response.begin()
  File "/usr/local/bin/iocage", line 10, in <module>
    sys.exit(cli())
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 722, in __call__
    return self.main(*args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 697, in main
    rv = self.invoke(ctx)
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 1066, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 895, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 535, in invoke
    return callback(*args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/iocage_cli/fetch.py", line 127, in cli
    ioc.IOCage().fetch(**kwargs)
  File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 970, in fetch
    **kwargs).fetch_release()
I have logged this as a bug so see if IX can help.
Jonathan
Andy C
pkg update
Joncy
You can still download releases and create jails from the FreeNAS command-line by specifying use a FreeBSD mirror. For example
# iocage fetch -s ftp5.fr.FreeBSD.org -d mirrors/ftp.freebsd.org/releases/amd64 -r 11.2-RELEASE
Adrian wrote a great tutorial about using iocage to create a LimeSurvey jail.
Then whenever this network issue is resolved, the jails will appear and may be managed using the GUI.
HTH - Andy
PS. I am following this thread with interest as I am also in London (VirginMedia ISP) and the site is accessible for me today.
Hazimil
OK, its working for me now with no errors. Must have been a routing issue, which is now resolved. Have left the bug open, as there might be way to manage the error better.
Have managed to do an iocage fetch and downloaded v11.3.
Jonathan
Andy C
I presume this is a very rare occurrence but I think iocage falls back to known FreeBSD mirrors if the first attempt fails.
sstruke
I have the same problems and it still doesn't work. Release is empty
Thadah
Using a VPN indeed allows me to connect to download.freeenas.org, seems my spanish ISP (MásMóvil) is blocking my access to the server.
