iSCSI extends missing after ZFS import
Trevorssn
Preface: New to FreeNas, Running in Home, Learning experience
Source of issue: Power had to be turned off to my house for an extended period while I was at work. The UPS finally gave out and FreeNAS lost power. When turning back on: met with Fatal Trap. After a while of tinkering the issue appeared to be with the USB drive. Imaged the USB and rebuilt. Got FreeNAS booting again and imported ZFS pool. Much happy :smile:
Noticed that the iSCSI extends seem to be not present.
And... what to do?
Rig:
Intel Core2 Duo
4 GB non-ECC
Z1
1.4TB
depasseg
FreeNAS Replicant
Did you import your backed up config? I might be wrong, but I don't think they just reappear. You might have to configure them.
gpsguy
Active Member
BTW, you only have 1/2 the minimum RAM needed for FreeNAS. And, it's recommended that you have at least 32GB RAM for iSCSI. 64+GB is even better.
Trevorssn
Thanks for replies. Checking when I return.
The RAM thing I knew going into it and performance is blah but passable for what I need.
Running on junked machines at the moment.
Trevorssn
Hmm it seems after further review I may have never backed up my config originally. That said I have found
Which looks convincingly enough like the size of my old extend. Any suggestions will be appreciated.
Also I have taken a backup of the current config for now: living and learning.
