Sure you can, just go into the Manual Setup mode. It will stripe the drive into your array, such that when any of the three drives fails, all data on the pool will be lost.Can I do what I am trying to do?
This is why I decided to make an account and create a post. I havent gotten a answer people can get behind. Who do I trust now? You say I can, but how? Im looking at my freenas page right now and when I did Storage->Volume Manager->Volume to extend->Extend volume, I get
- You are trying to add a virtual device consisting of 1 device(s) in a pool that has a virtual device consisting of 2 device(s)
Hello. I am having a similar problem to many that I've read, but with some differences. I wish to expand a 6TB pool (2x3TB, no RAID) with another 3TB drive. I try to expand the pool but am given that message about trying to add 1 drive to a 2 drive config. Can I do what I am trying to do? Do I instead need to add 2x1.5TB to the pool? There must be some way to expand a pool. I am using FreeNAS 9.10.2-U1 on a virtual system. Each of my current pools (there are 4) reside on different SAN volumes.
Thanks for any help you can give.
Assuming you want to keep redundancy in your pool, you need to add a pair of drives as another mirror to the mirror.
Or alternatively, backup, then change your pool to raidz1, then restore.
Or alternatively, jiggle around with disks and unsupported hacks, and degraded temporary pools and change your pool to raidz1
When I go into manual mode, it states it will erase the existing data. I can't have that.Sure you can, just go into the Manual Setup mode. It will stripe the drive into your array, such that when any of the three drives fails, all data on the pool will be lost.
Since you don't tell us to hardware specs or pool layout we have no way of knowing that you are using. You mention no raid which is great because no one should ever be using raid with zfs. So you you chill out and be nice to people who are helping you.Stux - please read in entirety before replying. To what redundancy are you referring?
Two devices doesn't mean there's a mirror. I also mention that it is a 6TB array (2x3TB, no RAID). Please stick to the question I'm asking. I do not wish to have this thread diverge from the actual need.A virtual device consisting of two devices is a mirror.
The message is trying to prevent adding a single disk stripe to a mirror.
I'm not trying to insult or be mean in any way. I am trying to stay focused on the problem. What hardware specs are you looking for? Glad to provide them.Since you don't tell us to hardware specs or pool layout we have no way of knowing that you are using. You mention no raid which is great because no one should ever be using raid with zfs. So you you chill out and be nice to people who are helping you.
If you want to stay on topic you already got your answer. Select your pool and EXTEND your pool with the new disk.I'm not trying to insult or be mean in any way. I am trying to stay focused on the problem. What hardware specs are you looking for? Glad to provide them.
No clue what your problem was since you still failed to explain your goal. But here is my example of adding a disk as a stripe to a pool. It works perfectly, no need to mess with disk sizes. You also seem like you are using virtual disks which is also another terrible idea. You will lose all this data and have terrible performance. Picture attached of me extending a pool.For everyone's reference, it seems that creating 2x1.5TB drives, rather than 1x3TB, enabled me to add the space to the pool.
zpool status
in code tags to see what you have now.A mirror is still RAID. It isn't RAIDZ, but it's still RAID. And two disks couldn't be RAIDZ anyway.That you had a 6TB pool (raw), with 2x3TB in a mirror, not in RaidZ
zpool status
. From what you wrote, your setup is terrible and **will** give you headaches. Let's see if we can do anything to improve that.
