iambenmitchell
- May 25, 2023
I am new to IPv6, but finally got it working on my LAN. My iPhone and Mac have IPv6 Addresses and the IPv6 test sites work fine.
I run a PiHole as a VM on my Truenas and would like to set it up to do ipv6 DNS requests too now.
However, I am running into issues as the VM seems to get an IPv6 address.. but does not have connectivity.
if I run the command 'netplan apply' in the vm, and immediately ping6 google.com, then it will correctly ping it 1 time with about 6ms latency.. and then stop working. So the VM must be getting the address correctly, I think there is an issue with the KVM stack.
Versions:
TrueNAS-SCALE-22.12.3.1
`ip a` output on truenas:
`ping6 google.com` truenas
`ip a` VM:
Ping VM:
Interestingly, it seems the VM can resolve google.com but not ping it's IPv6
Versions:
2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether d8:5e:d3:20:0c:e5 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.2/24 brd 192.168.1.255 scope global dynamic enp2s0
valid_lft 6709sec preferred_lft 6709sec
inet6 2a05:XXX:1:YYY:da5e:d3ff:fe20:ce5/64 scope global dynamic mngtmpaddr
valid_lft 86017sec preferred_lft 14017sec
inet6 fe80::da5e:d3ff:fe20:ce5/64 scope link
valid_lft forever preferred_lft forever`ping6 google.com` truenas
root@truenas[~]# ping6 google.com PING google.com(lhr48s27-in-x0e.1e100.net (2a00:1450:4009:815::200e)) 56 data bytes 64 bytes from lhr48s27-in-x0e.1e100.net (2a00:1450:4009:815::200e): icmp_seq=1 ttl=119 time=5.97 ms 64 bytes from lhr48s27-in-x0e.1e100.net (2a00:1450:4009:815::200e): icmp_seq=2 ttl=119 time=6.66 ms 64 bytes from lhr48s27-in-x0e.1e100.net (2a00:1450:4009:815::200e): icmp_seq=3 ttl=119 time=5.76 ms 64 bytes from lhr48s27-in-x0e.1e100.net (2a00:1450:4009:815::200e): icmp_seq=4 ttl=119 time=6.85 ms ^C --- google.com ping statistics --- 4 packets transmitted, 4 received, 0% packet loss, time 3005ms rtt min/avg/max/mdev = 5.758/6.308/6.849/0.456 ms
`ip a` VM:
2: ens3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:a0:98:39:21:1b brd ff:ff:ff:ff:ff:ff
altname enp0s3
inet 192.168.1.4/24 metric 100 brd 192.168.1.255 scope global dynamic ens3
valid_lft 6540sec preferred_lft 6540sec
inet6 ABCD:EFGH:1:ABCD::1:180e/128 scope global dynamic noprefixroute
valid_lft 5455sec preferred_lft 2755sec
inet6 ABCD:EFGH:1:ABCD:2a0:98ff:fe39:211b/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 86231sec preferred_lft 14231sec
inet6 fe80::2a0:98ff:fe39:211b/64 scope link
valid_lft forever preferred_lft foreverPing VM:
root@pihole:~# ping6 google.com PING google.com(lhr25s33-in-x0e.1e100.net (2a00:1450:4009:81f::200e)) 56 data bytes ^C --- google.com ping statistics --- 5 packets transmitted, 0 received, 100% packet loss, time 4104ms root@pihole:~#
