SOLVED IPMI update
NasKar
I have a ASROCK E3C226D2I which I can no longer access the remote console. BMC update 28 says it's fixed a JAVA incompatibility which is what I think is the issue. I can't seem to update my BMC from the IPMI web page. It hangs on uploading firmware image. Any ideas on what is preventing it from asking me where my BMC firmware is located on my local computer? I've turned off my popup blocker on chrome.
Chris Moore
You might need to try some other browsers. I have run into strange issues that wouldn't work from Chrome or Firefox and I ended up using Edge because it worked where both of the others were blocking it somehow.
NasKar
Chrome, Firefox, Edge all didn't work but Internet Explorer did. Thanks
Chris Moore
inpersonnate
For others who may have issues, here's what I did in Chrome...
1. Log in to BMC
2. Open Chrome Dev Tools
3. Switch to Application tab. Expand "Cookies" and click the appropriate domain name for your server.
4. At the end of the existing cookie list, double click the empty spot. Enter "WebServer" under name.
5. Should be good to go now.
