IP over Infiniband: fatal Kernel trap 12 after packet length >2044 bytes in connected mode
getcom
Hello all,
we have a problem on a FreeNAS iSCSI server (release is FreeNAS-11.2-U5).
We have a dual port Mellanox Infiniband ConnectX-3 card which is connected to a Infiniband switch (Grid Director 4036).
We have three Proxmox cluster nodes connected to the switch, which are running Proxmox VE 5.4-13.
The Infiniband cards on both ends are configured for connected mode with a MTU of 40950.
We are using a multipath setup with two subnets for IP over Infiniband.
This is working and we get a throughput of ~1-1.1 Gigabyte per second on each cluster node in parallel.
Sporadically we get a kernel trap on the FreeNAS server which is then rebooting.
This can happen from every hours up to 4 days.
The VMs are not crashing, they are in a delay until the FreeNAS server is online again.
Nevertheless we have to fix it.
The root cause is a packet over ipoib with a length >2044 bytes.
We are wondering where it comes from.
In a Linux Infiniband kernel documentation we found this:
In datagram mode, the IB UD (Unreliable Datagram) transport is used and so the interface MTU has is equal to the IB L2 MTU minus the IPoIB encapsulation header (4 bytes). For example, in a typical IB fabric with a 2K MTU, the IPoIB MTU will be 2048 - 4 = 2044 bytes. In connected mode, the IB RC (Reliable Connected) transport is used.
Connected mode takes advantage of the connected nature of the IB transport and allows an MTU up to the maximal IP packet size of 64K, which reduces the number of IP packets needed for handling large UDP datagrams, TCP segments, etc and increases the performance for large messages.
In connected mode, the interface's UD QP is still used for multicast and communication with peers that don't support connected mode. In this case, RX emulation of ICMP PMTU packets is used to cause the networking stack to use the smaller UD MTU for these neighbours.
Because of the overall performance we assume that we have multicast package problem here?
Has somebody any hint where we could look for the root cause?
Does anybody has an idea where the 4188 bytes packet come from?
Thank you in advance.
D
dlavigne
Guest
If you decide to report this at bugs.ixsystems.com, post the issue number here.
getcom
I should have to investigate in this problem and found out what is going on before I will report a bug anywhere.
I analyzed the FreeNAS crash dumps in /data/crash/ and found out that the last what is happening before the kernel is crashing are events like that:
<118>Fri Sep  6 05:20:07 CEST 2019
<6>arp: 10.20.24.111 moved from 80:00:02:08:fe:80:00:00:00:00:00:00:00:02:c9:03:00:09:9f:c1 to 80:00:02:09:fe:80:00:00:00:00:00:00:00:02:c9:03:00:09:9f:c2 on ib0
<6>arp: 10.20.24.110 moved from 80:00:02:08:fe:80:00:00:00:00:00:00:00:02:c9:03:00:09:20:e3 to 80:00:02:09:fe:80:00:00:00:00:00:00:00:02:c9:03:00:09:20:e4 on ib0
<6>arp: 10.20.25.111 moved from 80:00:02:09:fe:80:00:00:00:00:00:00:00:02:c9:03:00:09:9f:c2 to 80:00:02:08:fe:80:00:00:00:00:00:00:00:02:c9:03:00:09:9f:c1 on ib1
<6>arp: 10.20.25.110 moved from 80:00:02:09:fe:80:00:00:00:00:00:00:00:02:c9:03:00:09:20:e4 to 80:00:02:08:fe:80:00:00:00:00:00:00:00:02:c9:03:00:09:20:e3 on ib1
<6>arp: 10.20.24.111 moved from 80:00:02:09:fe:80:00:00:00:00:00:00:00:02:c9:03:00:09:9f:c2 to 80:00:02:08:fe:80:00:00:00:00:00:00:00:02:c9:03:00:09:9f:c1 on ib0
<4>ib0: packet len 12380 (> 2044) too long to send, dropping
It is every time the same behavior. The both 20-octet IPoIB link-layer addresses on all three Proxmox clients are changing from time to time.
After that it looks like that the FreeBSD server sometimes is using the Datagram mode for the new connections and then it tries to send a large packet over this connection which could come from a previous client request/connection in Connected mode.
The root cause seems to be the changing of the IP addresses/link layer addresses on the Proxmox client side and secondary the Datagram mode behavior on the FreeBSD side.
I will report that also in the Proxmox forum. Maybe somebody has an idea what is happening here with the link layer addresses and how to avoid that.
Here are more details of the setup:
On the FreeNAS side I`m using an own subnet for each IB port and I have two portals in the iSCSI setup for each IP (10.20.24.100/24 & 10.20.25.100/24).
The kernel of FreeNAS:
root@freenas1[/data/crash]# uname -a
FreeBSD freenas1.getcom.de 11.2-STABLE FreeBSD 11.2-STABLE #0 r325575+6aad246318c(HEAD): Mon Jun 24 17:25:47 UTC 2019     root@nemesis:/freenas-releng/freenas/_BE/objs/freenas-releng/freenas/_BE/os/sys/FreeNAS.amd64  amd64
The modules loaded on FreeNAS side:
root@freenas1[/data/crash]# cat /boot/loader.conf.local
mlx4ib_load="YES" # Be sure that Kernel modul Melloanox 4 Infiniband will be loaded
ipoib_load="YES" # Be sure that Kernel modul IP over Infiniband will be loaded
kernel="kernel"
module_path="/boot/kernel;/boot/modules;/usr/local/modules"
kern.cam.ctl.ha_id=0
root@freenas1[/data/crash]# kldstat
Id Refs Address            Size     Name
 1   72 0xffffffff80200000 25608a8  kernel
 2    1 0xffffffff82762000 100eb0   ispfw.ko
 3    1 0xffffffff82863000 f9f8     ipmi.ko
 4    2 0xffffffff82873000 2d28     smbus.ko
 5    1 0xffffffff82876000 8a10     freenas_sysctl.ko
 6    1 0xffffffff8287f000 3aff0    mlx4ib.ko
 7    1 0xffffffff828ba000 1a388    ipoib.ko
 8    1 0xffffffff82d11000 32e048   vmm.ko
 9    1 0xffffffff83040000 a74      nmdm.ko
10    1 0xffffffff83041000 e610     geom_mirror.ko
11    1 0xffffffff83050000 3a3c     geom_multipath.ko
12    1 0xffffffff83054000 2ec      dtraceall.ko
13    9 0xffffffff83055000 3acf8    dtrace.ko
14    1 0xffffffff83090000 5b8      dtmalloc.ko
15    1 0xffffffff83091000 1898     dtnfscl.ko
16    1 0xffffffff83093000 1d31     fbt.ko
17    1 0xffffffff83095000 53390    fasttrap.ko
18    1 0xffffffff830e9000 bfc      sdt.ko
19    1 0xffffffff830ea000 6d80     systrace.ko
20    1 0xffffffff830f1000 6d48     systrace_freebsd32.ko
21    1 0xffffffff830f8000 f9c      profile.ko
22    1 0xffffffff830f9000 13ec0    hwpmc.ko
23    1 0xffffffff8310d000 7340     t3_tom.ko
24    2 0xffffffff83115000 ab8      toecore.ko
25    1 0xffffffff83116000 ddac     t4_tom.ko
Kernel running on Proxmox:
root@pvecn1:~# uname -a
Linux pvecn1 4.15.18-20-pve #1 SMP PVE 4.15.18-46 (Thu, 8 Aug 2019 10:42:06 +0200) x86_64 GNU/Linux
The modules loaded on Proxmox side:
root@pvecn1:~# cat /etc/modules-load.d/mellanox.conf
mlx4_core
mlx4_ib
mlx4_en
ib_cm
ib_core
ib_ipoib
ib_iser
ib_umad
root@pvecn1:~# lsmod
Module                  Size  Used by
tcp_diag               16384  0
inet_diag              24576  1 tcp_diag
veth                   16384  0
nfsv3                  40960  2
nfs_acl                16384  1 nfsv3
nfs  262144 4 nfsv3
lockd                  94208  2 nfsv3,nfs
grace                  16384  1 lockd
fscache                65536  1 nfs
ip_set                 40960  0
ip6table_filter        16384  0
ip6_tables             28672  1 ip6table_filter
iptable_filter         16384  0
bonding  163840 0
softdog                16384  2
nfnetlink_log          20480  1
nfnetlink              16384  3 ip_set,nfnetlink_log
ipmi_ssif              32768  0
intel_rapl             20480  0
sb_edac                24576  0
x86_pkg_temp_thermal    16384  0
intel_powerclamp       16384  0
coretemp               16384  0
kvm_intel  217088 12
kvm  598016 1 kvm_intel
irqbypass  16384 20 kvm
crct10dif_pclmul       16384  0
crc32_pclmul           16384  0
ghash_clmulni_intel    16384  0
pcbc                   16384  0
vhost_net              24576  5
vhost                  45056  1 vhost_net
tap                    24576  1 vhost_net
iscsi_tcp  20480 129
aesni_intel  188416 0
libiscsi_tcp           20480  1 iscsi_tcp
ib_umad                24576  4
aes_x86_64             20480  1 aesni_intel
ib_iser                49152  0
crypto_simd            16384  1 aesni_intel
glue_helper            16384  1 aesni_intel
rdma_cm                61440  1 ib_iser
cryptd                 24576  3 crypto_simd,ghash_clmulni_intel,aesni_intel
iw_cm                  45056  1 rdma_cm
libiscsi               57344  3 libiscsi_tcp,iscsi_tcp,ib_iser
mgag200                45056  1
scsi_transport_iscsi    98304  4 iscsi_tcp,ib_iser,libiscsi
ttm  102400 1 mgag200
snd_pcm                98304  0
ib_ipoib  102400 0
snd_timer              32768  1 snd_pcm
drm_kms_helper  172032 1 mgag200
intel_cstate           20480  0
snd                    81920  2 snd_timer,snd_pcm
ib_cm                  53248  2 rdma_cm,ib_ipoib
soundcore              16384  1 snd
drm  401408 4 drm_kms_helper,mgag200,ttm
mlx4_en  114688 0
i2c_algo_bit           16384  1 mgag200
intel_rapl_perf        16384  0
pcspkr                 16384  0
input_leds             16384  0
joydev                 20480  0
fb_sys_fops            16384  1 drm_kms_helper
syscopyarea            16384  1 drm_kms_helper
sysfillrect            16384  1 drm_kms_helper
sysimgblt              16384  1 drm_kms_helper
mei_me                 40960  0
mei                    94208  1 mei_me
ioatdma                53248  0
lpc_ich                24576  0
shpchp                 36864  0
wmi                    24576  0
ipmi_si                61440  0
ipmi_devintf           20480  0
ipmi_msghandler        53248  3 ipmi_devintf,ipmi_si,ipmi_ssif
acpi_pad  180224 0
mac_hid                16384  0
dm_round_robin  16384 21
dm_multipath  28672 22 dm_round_robin
scsi_dh_rdac           16384  0
scsi_dh_emc            16384  0
scsi_dh_alua  20480 63
mlx4_ib  176128 0
ib_core  225280 7 rdma_cm,ib_ipoib,mlx4_ib,iw_cm,ib_iser,ib_umad,ib_cm
sunrpc  335872 22 lockd,nfsv3,nfs_acl,nfs
ip_tables              28672  1 iptable_filter
x_tables               40960  4 ip6table_filter,iptable_filter,ip6_tables,ip_tables
autofs4                40960  2
zfs  3452928 4
zunicode  331776 1 zfs
zavl                   16384  1 zfs
icp  258048 1 zfs
zcommon                69632  1 zfs
znvpair                77824  2 zfs,zcommon
spl  106496 4 zfs,icp,znvpair,zcommon
btrfs  1130496 0
xor                    24576  1 btrfs
zstd_compress  167936 1 btrfs
raid6_pq  114688 1 btrfs
hid_generic            16384  0
usbkbd                 16384  0
usbmouse               16384  0
usbhid                 49152  0
hid  118784 2 usbhid,hid_generic
ahci                   40960  0
i2c_i801               28672  0
libahci                32768  1 ahci
isci  139264 2
libsas                 77824  1 isci
scsi_transport_sas     40960  2 isci,libsas
i40e  331776 0
mlx4_core  294912 2 mlx4_ib,mlx4_en
igb  196608 0
dca                    16384  2 igb,ioatdma
devlink                45056  3 mlx4_core,mlx4_ib,mlx4_en
ptp                    20480  3 i40e,igb,mlx4_en
pps_core               20480  1 ptp
The network setup for example on the first Proxmox client:
# Mellanox Infiniband
auto ib0
iface ib0 inet static
    address  10.20.24.110
    netmask  255.255.255.0
    pre-up echo connected > /sys/class/net/$IFACE/mode
    #post-up /sbin/ifconfig $IFACE mtu 65520
    post-up /sbin/ifconfig $IFACE mtu 40950
auto ib1
iface ib1 inet static
    address  10.20.25.110
On the Proxmox side I`m running a multipath setup.
This is the content of /etc/multipath.conf:
defaults {
        polling_interval        2
        path_selector           "round-robin 0"
        path_grouping_policy    multibus
        uid_attribute           ID_SERIAL
        rr_min_io_rq            1
        rr_weight               uniform
        failback                immediate
        no_path_retry           queue
        user_friendly_names     yes
blacklist {
        devnode "^(ram|raw|loop|fd|md|dm-|sr|scd|st)[0-9]*"
        devnode "^(td|hd)[a-z]"
        devnode "^dcssblk[0-9]*"
        devnode "^cciss!c[0-9]d[0-9]*"
        device {
                vendor "DGC"
                product "LUNZ"
        device {
                vendor "EMC"
                product "LUNZ"
        device {
                vendor "IBM"
                product "Universal Xport"
        device {
                vendor "IBM"
                product "S/390.*"
        device {
                vendor "DELL"
        device {
                vendor "SGI"
        device {
                vendor "STK"
        device {
                vendor "SUN"
        device {
                vendor "(NETAPP|LSI|ENGENIO)"
blacklist_exceptions {
        wwid "36589cfc000000ba043795f1aaa24a764"
        wwid "36589cfc0000001dd62faaaaa75d7c679"
        wwid "36589cfc0000007aea1572aaef3aec823"
        wwid "36589cfc0000009e1e93487c97aae9a54"
        wwid "36589cfc000000f635efd89cb87f03890"
        wwid "36589cfc000000563c0c9bb4a2e354f25"
        wwid "36589cfc0000008bae6fc06d5e0c88172"
        wwid "36589cfc0000005a963aa288b259f58e4"
        wwid "36589cfc000000a4054637fc225b8e98f"
        wwid "36589cfc000000b7d308a80c43d99bcf1"
        wwid "36589cfc000000ecc18d003644fc0e791"
        wwid "36589cfc0000008e202c2cd920e0eae8d"
        wwid "36589cfc0000001c5c48ed15790210293"
        wwid "36589cfc0000003dff6c09aea0a3dde3f"
        wwid "36589cfc000000ac16a0f04a4d0b9b80c"
        wwid "36589cfc0000008b9453ba6f4f7208a08"
        wwid "36589cfc000000bef6e9ccda0bfeedc7e"
        wwid "36589cfc000000f62a06da4e537faf8a5"
        wwid "36589cfc000000a1c16d9b9b4fd27cf45"
        wwid "36589cfc0000001d5698dd929a4db723b"
        wwid "36589cfc000000fa534d1f6243e35b48a"
multipaths {
  multipath {
    alias mpath100d0
  multipath {
    alias mpath101d0
  multipath {
    alias mpath102d0
  multipath {
    alias mpath103d0
  multipath {
    alias mpath104d0
  multipath {
    alias mpath105d0
  multipath {
    alias mpath106d0
  multipath {
    alias mpath107d0
  multipath {
    alias mpath108d0
  multipath {
    alias mpath108d1
  multipath {
    alias mpath109d1
  multipath {
    alias mpath109d2
  multipath {
    alias mpath109d3
  multipath {
    alias mpath109d4
  multipath {
    alias mpath110d0
  multipath {
    alias mpath110d1
  multipath {
    alias mpath110d2
  multipath {
    alias mpath111d0
  multipath {
    alias mpath111d1
  multipath {
    alias mpath112d0
  multipath {
    alias mpath112d1
ifconfig for the both Infiniband ports on the FreeNAS server looks like that:
ib0: flags=8043<UP,BROADCAST,RUNNING,MULTICAST> metric 0 mtu 40950
    options=80018<VLAN_MTU,VLAN_HWTAGGING,LINKSTATE>
    lladdr 80.0.2.8.fe.80.0.0.0.0.0.0.0.2.c9.3.0.3a.ed.41
    inet 10.20.24.210 netmask 0xffffff00 broadcast 10.20.24.255
ib1: flags=8043<UP,BROADCAST,RUNNING,MULTICAST> metric 0 mtu 40950
    lladdr 80.0.2.9.fe.80.0.0.0.0.0.0.0.2.c9.3.0.3a.ed.42
    inet 10.20.25.210 netmask 0xffffff00 broadcast 10.20.25.255
ifconfig on the first Proxmox client:
ib0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 40950
        inet 10.20.24.110  netmask 255.255.255.0  broadcast 10.20.24.255
        inet6 fe80::202:c903:9:20e3  prefixlen 64  scopeid 0x20<link>
        unspec 80-00-02-08-FE-80-00-00-00-00-00-00-00-00-00-00  txqueuelen 256  (UNSPEC)
        RX packets 5596912  bytes 10293861835 (9.5 GiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 3744669  bytes 48471009082 (45.1 GiB)
        TX errors 0  dropped 125 overruns 0  carrier 0  collisions 0
ib1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 40950
        inet 10.20.25.110  netmask 255.255.255.0  broadcast 10.20.25.255
        inet6 fe80::202:c903:9:20e4  prefixlen 64  scopeid 0x20<link>
        unspec 80-00-02-09-FE-80-00-00-00-00-00-00-00-00-00-00  txqueuelen 256  (UNSPEC)
        RX packets 6863837  bytes 8858149718 (8.2 GiB)
        TX packets 6197948  bytes 96516756048 (89.8 GiB)
        TX errors 0  dropped 257 overruns 0  carrier 0  collisions 0
getcom
Hello all,
I think I have found an answer to the address change problem on the Linux clients:
I found a comment on embeddedlinux.org:
  • A Linux host replies to any ARP solicitation requests that specify a target IP address configured on any of its interfaces, even if the request was received on this host by a different interface. To make Linux behave as if addresses belong to interfaces, administrators can use the ARP_IGNORE feature described later in the section "/proc Options."
  • Hosts can experience the ARP flux problem, in which the wrong interface becomes associated with an L3 address. This problem is described in the text that follows.
other sources:
http://www.mellanox.com/related-doc...OFED_Release_Notes-1.5.1-1.3.6_for_Oracle.txt
- When multiple vNics are connected to the same network, hosts can experience the "ARP flux" problem, in which the wrong interface becomes associated with an L3 address (FM #87335).
Workaround:
Set the following kernel configuration parameters: include the following lines in /etc/sysctl.conf and reboot the machine:
net.ipv4.conf.all.arp_ignore=1
net.ipv4.conf.all.arp_announce=2
https://downloads.openfabrics.org/O...release/OFED-1.4-docs/ipoib_release_notes.txt
3. Known Issues ===============================================================================
1. If a host has multiple interfaces and
(a) each interface belongs to a different IP subnet,
(b) they all use the same InfiniBand Partition, and
(c) they are connected to the same IB Switch,
then the host violates the IP rule requiring different broadcast domains.
Consequently, the host may build an incorrect ARP table.
The correct setting of a multi-homed IPoIB host is achieved by using a different PKEY for each IP subnet.
If a host has multiple interfaces on the same IP subnet, then to prevent a peer from building an incorrect ARP entry (neighbor) set the net.ipv4.conf.X.arp_ignore value to 1 or 2, where X stands for the IPoIB (non-child) interfaces (e.g., ib0, ib1, etc). This causes the network stack to send ARP replies only on the interface with the IP address specified in the ARP request:
sysctl -w net.ipv4.conf.ib0.arp_ignore=1
sysctl -w net.ipv4.conf.ib1.arp_ignore=1
Or, globally,
sysctl -w net.ipv4.conf.all.arp_ignore=1
For the running kernel on each client I executed following:
echo 1 > /proc/sys/net/ipv4/conf/all/arp_ignore; echo 2 > /proc/sys/net/ipv4/conf/all/arp_announce; echo 1 >/proc/sys/net/ipv4/conf/ib0/arp_ignore; echo 1 >/proc/sys/net/ipv4/conf/ib1/arp_ignore
I added the corresponding post-up lines to /etc/network/interface to get it permanent.
Hopefully the kernel trap 12 is gone now.
I received an arp address change message on server side every 1 to 15 minutes. This is gone now.
There are no such arp messages since 2 hours.
Surprisingly I could also switch to a MTU of 65520 which was not working previously without lots of connection errors on each client.
On one client there is still something what I have to check. I had two events like that:
connection3:0: ping timeout of 5 secs expired, recv timeout 5, last rx 4408262456, last ping 4408263744, now 4408265024
Sep 9 04:53:45 pvecn3 kernel: [453492.780173] connection3:0: detected conn error (1022)
Sep 9 04:53:45 pvecn3 kernel: [453492.780363] scsi_io_completion: 10 callbacks suppressed
Conclusion:
FreeBSD/FreeNAS is doing a good job, Linux was the problem child.
Regards,
Ralf
