dlobel
- Feb 19, 2021
Hi there,
I'm trying to get my Hikvision cam (model DS-2DE2A404IW-DE3) running on TrueNAS-12.0-U2.1 under a Homebridge Jail.
The Homebridge jail is working well and I've been able to connect my Ring cams, Nest Thermostat and Tuya light devices. But I can't get the IP Camera to work.
In VLC the RTSP stream is working fine: rtsp://user:passw@192.168.1.64:554/ISAPI/Streaming/channels/101 ... (or substream 102)
When manually installing the FFMPEG plugin, I get an error that FreeBSD X86 is not supported and the I should install/compile manually? Is there anybody who's succesfully running an IP CAM under a Homebridge Jail via de FFMPEG plugin?
For testen purposes, I installed a separate Homebridge on my Mac. In less then 5 minutes I got the Hikvision camera working.
So the Homebridge FFMPEG plugin under FreeBSD is the issue.
Any help will be appreciated!
