iohvye Question
Kanky
Hi Guys,
I am following this thread to guide me from VirtualBox to bhyve.
https://blog.yuo.be/2017/01/04/migrating-a-vm-from-virtualbox-to-iohyve-bhyve-on-freenas-9-10/
However, I am stuck with this command.
dd if=/mnt/Main/jails/Production/tmp/SDB.Raw of=/dev/zvol/Tank/iohyve/SDB/Disk0
I cannot see any progress on the terminal, and when I use WinSCP to look at the file directory, disk0 size is 0 KB but the modified timestamp updates every second. The raw file is ~65gb.
I also notice that the Pool name is different on the between destinations. Does this matter?
Thanks
Kanky
I waited for an hour and it didnt finish. The destination file never went above 0 KB but the timestamp updated every second.
I tried using cp and that failed at 99% it said Operation not supported or something similar.
At that stage I rolled back to the earlier version that allowed me to run VirtualBox.
