adrianwi
- Oct 15, 2013
I managed to build myself a jail to run LimeSurvey in, which appears to be working remarkably well :) If I can do it again, I might even make a 'How to...' guide!
I mistakenly created the jail using 11.1-RELEASE so after creating thought I'd upgrade it using
It was taking some time, but eventually completed and said I needed to reboot and then install a file it had created in /tmp (can't remember the name)
I rebooted FreeNAS but when I looked in the /tmp folder the tmp file had gone. Everything started up OK, so thought I'd try again.
Seemed to take less time, but then I got this:
After so many 'y' responses, I was beginning to think maybe this wasn't a great idea so selected 'n' and then got the traceback.
Any ideas what's gone wrong as I'd upgraded jails in the past (from 11.1 to 11.2) and all my others are running 11.2?
Thanks
iocage upgrade -r 11.2-RELEASE limesurvey
Preparing to download files... done. /tmp/tmp4m16fxr0: cannot open files/.gz: No such file or directory (about 50 times) Attempting to automatically merge changes in files... done. The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /boot/device.hints Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/amd.map Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/apmd.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/auto_master Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/autofs/include_ldap Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/autofs/include_nis Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/autofs/include_nis_nullfs Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/autofs/special_hosts Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/autofs/special_media Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/autofs/special_noauto Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/autofs/special_null Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/blacklistd.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/bluetooth/hcsecd.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/bluetooth/hosts Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/bluetooth/protocols Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/crontab Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/csh.cshrc Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/csh.login Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/csh.logout Does this look reasonable (y/n)? yy The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/ddb.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/defaults/bluetooth.device.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/defaults/devfs.rules Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/defaults/periodic.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/defaults/rc.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/devd.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/devd/asus.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/devd/hyperv.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/devd/uath.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/devd/ulpt.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/devd/usb.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/devd/zfs.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/devfs.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/dhclient.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/disktab Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/dma/dma.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/fbtab Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/ftpusers Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/gettytab Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/gss/mech Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/gss/qop Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/hosts.allow Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/hosts.equiv Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/hosts.lpd Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/inetd.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/libalias.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/libmap.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/locate.rc Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/login.access Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/login.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mac.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/Makefile Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/README Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/access.sample Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/aliases Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/freebsd.cf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/freebsd.mc Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/freebsd.submit.cf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/freebsd.submit.mc Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/mailer.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/mailertable.sample Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/sendmail.cf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/submit.cf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mail/virtusertable.sample Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mtree/BSD.debug.dist Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mtree/BSD.include.dist Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mtree/BSD.lib32.dist Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mtree/BSD.root.dist Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mtree/BSD.sendmail.dist Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mtree/BSD.tests.dist Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mtree/BSD.usr.dist Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/mtree/BSD.var.dist Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/netconfig Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/netstart Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/network.subr Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/networks Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/newsyslog.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/nscd.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/nsmb.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/nsswitch.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/ntp.conf Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/opieaccess Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/README Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/atrun Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/cron Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/ftp Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/ftpd Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/imap Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/login Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/other Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/passwd Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/pop3 Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/rsh Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/sshd Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/su Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/system Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/telnetd Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pam.d/xdm Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/pccard_ether Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/100.clean-disks Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/110.clean-tmps Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/120.clean-preserve Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/130.clean-msgs Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/140.clean-rwho Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/150.clean-hoststat Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/200.backup-passwd Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/210.backup-aliases Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/300.calendar Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/310.accounting Does this look reasonable (y/n)? yy The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/330.news Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/400.status-disks Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/401.status-graid Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/404.status-zfs Does this look reasonable (y/n)? y The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/406.status-gmirror Does this look reasonable (y/n)? yy The following file will be removed, as it no longer exists in FreeBSD 11.2-RELEASE: /etc/periodic/daily/407.status-graid3 Does this look reasonable (y/n)? n Traceback (most recent call last): File "/usr/local/bin/iocage", line 10, in <module> sys.exit(cli()) File "/usr/local/lib/python3.6/site-packages/click/core.py", line 722, in __call__ return self.main(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/click/core.py", line 697, in main rv = self.invoke(ctx) File "/usr/local/lib/python3.6/site-packages/click/core.py", line 1066, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File "/usr/local/lib/python3.6/site-packages/click/core.py", line 895, in invoke return ctx.invoke(self.callback, **ctx.params) File "/usr/local/lib/python3.6/site-packages/click/core.py", line 535, in invoke return callback(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/iocage_cli/upgrade.py", line 39, in cli ioc.IOCage(jail=jail, skip_jails=True).upgrade(release) File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1838, in upgrade root_path).upgrade_jail() File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_upgrade.py", line 116, in upgrade_jail raise RuntimeError("Error occured, jail not upgraded!") RuntimeError: Error occured, jail not upgraded! root@freenas1:~ #
Thanks
