Iocage jail
Scareh
Been seeing for a while now whenever i open my plex that there is an update available. Whenever i go to my jail tab in my GUI, i only see the Update button. Which i understand updates the jail towards an higher bsd version?
Is there any automated way to update the iocage jails like there was with the old plugin system? I know it's possible to do so via the command line, but that seems to defeat the point off having a pluginjail....
side questions:
https://redmine.ixsystems.com/issues/37806 any update on the sabnzdb plugin?
I'm also still missing the nzbhydra and nzbhydra2 plugins (https://github.com/theotherp/nzbhydra2)
D
dlavigne
Guest
The ability to do this from the UI is coming in 11.3. Til then, you can upgrade from the CLI.
Scareh
allright thanks for the info dlavigne.
Any info on the sab plugin status? as Disk Idler seems to have provided a whole working plugin, seems kinda strange it's lagging behind so much.
D
dlavigne
Guest
We'll add the nzbhydra to the next plugins update blog post in the Call for Testers section. Do you know the location for the Sab plugin? The one in that ticket looks quite old and incomplete.
Anicet
Hi, care to share link to the blog and did nzbhydra make it to the plugings?
