SOLVED iocage jail not autostart after upgrade 11.2 U2
hylyah
All my jail (iocage) not start auto since last upgrade to 11.2 U2 even if "Auto-start" is enable.
I can start all jail manually and it's works...
Any solution ? (other than downgrade to U1)
Thx :)
hylyah
The boot log on attached file
  • messages.txt
D
dlavigne
Guest
I wonder if it's a timing issue with the availability of the NICs:
Mar 5 08:34:50 freenas kernel: bge0: link state changed to DOWN
Mar 5 08:34:50 freenas kernel: bge0: link state changed to UP
Mar 5 08:34:50 freenas kernel: bge1: link state changed to DOWN
Which one are you using for the jails? Are you using static IPs or DHCP?
Mannekino
Can you post a screenshot of the network settings or the configuration file of the jail?
Are you on 11.2-U2 or 11.2-U2.1 there was a bug with network settings for jails which was fixed in 11.2-U2.1.
hylyah
I try to downgrade to the last version but same problème but I'havn't before upgrade...
Nvious1
Still can you tell us what release you are on?
If you create a new jail with auto-boot on does it start up on creation?
iocage create -n "jailTest1" -r 11.2-RELEASE vnet="on" bpf="yes" dhcp="on" boot="on"
hylyah
I create new jail via the GUI, and restart, the result is this jail is not started
hylyah
I create a jail with "iocage create -n "jailTest1" -r 11.2-RELEASE vnet="on" bpf="yes" dhcp="on" boot="on", nothing change, same problem.
