Iocage Image permission
Dellyjoe
Hello everyone, I was trying to mount the iocage for both my pools Tank 1 and Tank 2, I was able to view everything on Tank 2 iocage images as normal on my nextcloud mount point, but not for the Tank 1 iocage image.
This seem to be b/c I don't have write or read within the iocage image
see picture below:
Does anyone know how to change the permisison within the /mnt/Tank1/iocage/images The chmod command doesn't seem to work?
Thank you for reading,
Joe
The + at the end of the permissions in the Tank1 folders indicate that you have ACLs set. These interfere with chmod and need to be managed differently. Please refer to the ACL management section in the documentation or search the forums for setfacl for more information.
Dellyjoe
@Jurgen Segaert Thank you for getting back to me, it looks like I can't access the ACL's with the GUI it states root dataset permissions cann't be edited, this is show for both Tank1 and Tank2, I was able to use chmod 755 to get Tank1 = Tank 2 but nextcloud still can't see files and
I did restart the jail nextcloud but nothing changed, I can still see Tank2 Images fine on nextcloud just not Tank1
Do you have an idea on why i can't access Tank1 or Tank2 ACL permissions, why they are grayed out?
Also now having the files be the same access, to me this doesn't seem like an access issue? what do you think?
Joe
The permissions between Tank1 and Tank2 look identical now, but there's not much information to go on.
What pool is your jail on and how did you end up with two iocage/image directory structures?
Are these both iocage-generated datasets, or is one of them a normal directory you created yourself? What are the exact mount-points you have added in your jail? These are nullfs mounts and can't traverse datasets.
Dellyjoe
@Jurgen Segaert Thank you for getting back to me, it turn out that after I corrected the permission between Tank1/iocage/images to Tank2/iocage/images I needed to re-due the mount point on nextcloud, not on the jail but on the web UI, it was really weird but i'm happy I figured it out.
Thank you for your help !!
Joe
