Intermittent filesystem hanging/lagging
tjlloyd76
Good afternoon all, I'm hoping maybe someone here might be able to help me out a bit. I've got a FreeNAS system that seems to hang or lag for extreme amounts of time from time to time. For example, I'm in the shell of my FreeNAS server simply trying to produce an "ls" of a folder. I literally typed "ls", hit enter, came over to this web site, reset my password (been a long time since I've logged in), logged in, browsed through the forums looking for the best place to post, started my post and it has STILL yet to produce the directory listing. It's not a massive directory either, about 30 files & folders. While this is happening, it seems like any kind of disk I/O request will suffer the same fate until it decides to start working again. Then everything is fine until it hangs up again. I'm not sure what information you all want or need, but here's some stuff right off the bat.
This is a Dell PowerEdge T710, I have FreeNAS installed on a SanDisk SSD. I've removed the stock RAID controller and replaced it with a SAS9211-8I 8PORT Int 6GB Sata+SAS Pcie 2.0. Currently have 4 WD Red, 4T (ATA WDC WD40EFRX-68N 0A82) drives installed as one encrypted volume and 4 1T Seagate drives (ATA ST1000DM003-1SB1 CC43) in an unencrypted pool. (I thought maybe my trouble was with the encryption, so I stood up another pool without encryption, but the issue persists on this pool as well)
root@freenas:/ # uname -a
FreeBSD freenas.local 11.2-STABLE FreeBSD 11.2-STABLE #0 r325575+5920981193f(HEAD): Mon Sep 16 23:00:13 UTC 2019 root@nemesis:/freenas-releng/freenas/_BE/objs/freenas-releng/freenas/_BE/os/sys/FreeNAS.amd64 amd64
root@freenas:/ # dmesg | grep CPU
CPU: Intel(R) Xeon(R) CPU E5620 @ 2.40GHz (2394.05-MHz K8-class CPU)
FreeBSD/SMP: Multiprocessor System Detected: 16 CPUs
root@freenas:/ # dmesg | grep memory
real memory = 12884901888 (12288 MB)
avail memory = 12407050240 (11832 MB)
Please let me know if you need any other information. I'd very much like to hear what solutions you may have to offer.
Thank you.
HoneyBadger
actually does care
Administrator
I would suspect a failing drive that is repeatedly timing out, but eventually returning the requested data.
Check the output of smartctl -a /dev/adaX and post the results for each drive inside of CODE tags here
Jailer
Not strong, but bad
NIC?
1kokies
Mmmm.......funny problem but it looks like a hardware issue.
tjlloyd76
@HoneyBadger, output exceeds post limit. I'll attach a log instead.
@Jailer, that's what I'd thought at first. However, I can have another ssh session open at the same time and still get responses (pings etc). So I started to rule out networking because the issue seems to be limited to disk I/O
  • putty1028.txt
Jailer
Not strong, but bad
You need to run long smart tests on all of your drives. None of them have periodic SMART tests set up to run and none of the WD drives have ever had SMART tests run on them.
tjlloyd76
Thank you for the direction.
I ran a long smart test on ada0 (boot drive),
root@freenas:~ # smartctl -a /dev/ada0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:     SanDisk SSD PLUS 120GB
Serial Number:    19121B804596
LU WWN Device Id: 5 001b44 8b860e4d4
Firmware Version: UE5000RL
User Capacity:    120,040,980,480 bytes [120 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-2 T13/2015-D revision 3
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Tue Oct 29 07:45:46 2019 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (  120) seconds.
capabilities:                    (0x15) SMART execute Offline immediate.
                                        No Auto Offline data collection support.
                                        Abort Offline collection upon new
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        No Selective Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (  21) minutes.
SMART Attributes Data Structure revision number: 1
  5 Reallocated_Sector_Ct   0x0032   100   100   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       712
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       9
165 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       223
166 Unknown_Attribute       0x0032   100   100   ---    Old_age   Always       -       1
167 Unknown_Attribute       0x0032   100   100   ---    Old_age   Always       -       0
168 Unknown_Attribute       0x0032   100   100   ---    Old_age   Always       -       2
169 Unknown_Attribute       0x0032   100   100   ---    Old_age   Always       -       108
170 Unknown_Attribute       0x0032   100   100   ---    Old_age   Always       -       0
171 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
172 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
173 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       1
174 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       10
184 End-to-End_Error        0x0032   100   100   ---    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   ---    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   075   040   000    Old_age   Always       -       25 (Min/Max 20/40)
199 UDMA_CRC_Error_Count    0x0032   100   100   ---    Old_age   Always       -       0
230 Unknown_SSD_Attribute   0x0032   100   100   000    Old_age   Always       -       270584250431
232 Available_Reservd_Space 0x0033   100   100   005    Pre-fail  Always       -       100
233 Media_Wearout_Indicator 0x0032   100   100   ---    Old_age   Always       -       6
234 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       1245
241 Total_LBAs_Written      0x0030   100   100   000    Old_age   Offline      -       378
242 Total_LBAs_Read         0x0030   100   100   000    Old_age   Offline      -       14
244 Unknown_Attribute       0x0032   000   100   ---    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%       711         -
# 2  Extended offline    Self-test routine in progress 40%       711         -
Selective Self-tests/Logging not supported
Started test on my first pool drive, it looks like it'll take around 8 hours each, so I'll have to update with those results later.
tjlloyd76
Ok, I've been away for a bit. Here are the smartctl results after a long test on each of my primary pool drives:
root@freenas:~ # smartctl -a /dev/da0
Model Family:     Western Digital Red
Device Model:     WDC WD40EFRX-68N32N0
Serial Number:    WD-WCC7K5LXD865
LU WWN Device Id: 5 0014ee 210f27591
Firmware Version: 82.00A82
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Nov  6 06:56:42 2019 PST
                                        was never started.
                                        been run.
data collection:                (43440) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 462) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x303d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   191   191   021    Pre-fail  Always       -       5433
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       22
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       4122
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       22
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       20
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       25
194 Temperature_Celsius     0x0022   129   115   000    Old_age   Always       -       21
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
No Errors Logged
# 1  Extended offline    Completed without error       00%      3956         -
root@freenas:~ # smartctl -a /dev/da1
Serial Number:    WD-WCC7K5LXDADJ
LU WWN Device Id: 5 0014ee 2bb9d7796
Local Time is:    Wed Nov  6 06:56:50 2019 PST
                                        was never started.
                                        been run.
data collection:                (42780) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 454) minutes.
  3 Spin_Up_Time            0x0027   188   188   021    Pre-fail  Always       -       5600
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       4129
194 Temperature_Celsius     0x0022   127   112   000    Old_age   Always       -       23
No Errors Logged
# 1  Extended offline    Completed without error       00%      3971         -
root@freenas:~ # smartctl -a /dev/da2
Serial Number:    WD-WCC7K0EVYJ4N
LU WWN Device Id: 5 0014ee 2bb9d915b
Local Time is:    Wed Nov  6 06:57:06 2019 PST
                                        was never started.
                                        been run.
data collection:                (42720) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 453) minutes.
  3 Spin_Up_Time            0x0027   185   185   021    Pre-fail  Always       -       5725
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       4120
194 Temperature_Celsius     0x0022   127   111   000    Old_age   Always       -       23
No Errors Logged
# 1  Extended offline    Completed without error       00%      3983         -
root@freenas:~ # smartctl -a /dev/da3
Serial Number:    WD-WCC7K1SEY0ZK
LU WWN Device Id: 5 0014ee 26647de73
Local Time is:    Wed Nov  6 06:57:12 2019 PST
                                        was never started.
                                        been run.
data collection:                (43080) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 457) minutes.
  3 Spin_Up_Time            0x0027   192   192   021    Pre-fail  Always       -       5400
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       4117
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       24
194 Temperature_Celsius     0x0022   128   113   000    Old_age   Always       -       22
No Errors Logged
# 1  Extended offline    Completed without error       00%      3991         -
