I'm sure this question has been asked several times, but in my searching I've found nothing pointing me toward a useful answer. Hopefully someone can help me.
I have a Xeon 1270 v6 (3.8GHz - 4.2GHz max boost) that seems to be locked at 3.8GHz in FreeNAS, and would like to find a way to unlock the performance I paid for.
Setup:
Here's the output of
I would expect the
Setup:
Intel Zeon E3-1270 v6 SuperMicro X11SSL-F Motherboard NEXMIX DDR4-2400 32GB (2x16) ECC Unbuffered RAM 2x LSI SAS JBOD cards
sysctl -a | grep -i cpu:Code:
kern.smp.cpus: 8
kern.smp.maxcpus: 256
kern.ccpu: 0
<cpu count="8" mask="ff,0,0,0">0, 1, 2, 3, 4, 5, 6, 7</cpu>
<cpu count="2" mask="3,0,0,0">0, 1</cpu>
<cpu count="2" mask="c,0,0,0">2, 3</cpu>
<cpu count="2" mask="30,0,0,0">4, 5</cpu>
<cpu count="2" mask="c0,0,0,0">6, 7</cpu>
kern.sched.cpusetsize: 32
kern.pin_pcpu_swi: 0
kern.racct.pcpu_threshold: 1
cpu HAMMER
device cpufreq
device cpuctl
kern.vt.splash_cpu_duration: 10
kern.vt.splash_cpu_style: 2
kern.vt.splash_ncpu: 0
kern.vt.splash_cpu: 0
vfs.ncpurgeminvnodes: 1024
net.inet.tcp.per_cpu_timers: 0
debug.cpufreq.verbose: 0
debug.cpufreq.lowest: 0
debug.acpi.cpu_unordered: 0
kdb.enter.default=write cn_mute 1; watchdog 38; capture on; bt; show allpcpu; ps ; alltrace; write cn_mute 0; textdump dump; reset
hw.model: Intel(R) Xeon(R) CPU E3-1270 v6 @ 3.80GHz
hw.ncpu: 8
hw.vmm.bhyve_xcpuids: 1117
hw.vmm.topology.cpuid_leaf_b: 1
hw.acpi.cpu.cx_lowest: C2
dev.cpufreq.7.%parent: cpu7
dev.cpufreq.7.%pnpinfo:
dev.cpufreq.7.%location:
dev.cpufreq.7.%driver: cpufreq
dev.cpufreq.7.%desc:
dev.cpufreq.6.%parent: cpu6
dev.cpufreq.6.%pnpinfo:
dev.cpufreq.6.%location:
dev.cpufreq.6.%driver: cpufreq
dev.cpufreq.6.%desc:
dev.cpufreq.5.%parent: cpu5
dev.cpufreq.5.%pnpinfo:
dev.cpufreq.5.%location:
dev.cpufreq.5.%driver: cpufreq
dev.cpufreq.5.%desc:
dev.cpufreq.4.%parent: cpu4
dev.cpufreq.4.%pnpinfo:
dev.cpufreq.4.%location:
dev.cpufreq.4.%driver: cpufreq
dev.cpufreq.4.%desc:
dev.cpufreq.3.%parent: cpu3
dev.cpufreq.3.%pnpinfo:
dev.cpufreq.3.%location:
dev.cpufreq.3.%driver: cpufreq
dev.cpufreq.3.%desc:
dev.cpufreq.2.%parent: cpu2
dev.cpufreq.2.%pnpinfo:
dev.cpufreq.2.%location:
dev.cpufreq.2.%driver: cpufreq
dev.cpufreq.2.%desc:
dev.cpufreq.1.%parent: cpu1
dev.cpufreq.1.%pnpinfo:
dev.cpufreq.1.%location:
dev.cpufreq.1.%driver: cpufreq
dev.cpufreq.1.%desc:
dev.cpufreq.0.%parent: cpu0
dev.cpufreq.0.%pnpinfo:
dev.cpufreq.0.%location:
dev.cpufreq.0.%driver: cpufreq
dev.cpufreq.0.%desc:
dev.cpufreq.%parent:
dev.est.7.%parent: cpu7
dev.est.6.%parent: cpu6
dev.est.5.%parent: cpu5
dev.est.4.%parent: cpu4
dev.est.3.%parent: cpu3
dev.est.2.%parent: cpu2
dev.est.1.%parent: cpu1
dev.est.0.%parent: cpu0
dev.coretemp.7.%parent: cpu7
dev.coretemp.7.%desc: CPU On-Die Thermal Sensors
dev.coretemp.6.%parent: cpu6
dev.coretemp.6.%desc: CPU On-Die Thermal Sensors
dev.coretemp.5.%parent: cpu5
dev.coretemp.5.%desc: CPU On-Die Thermal Sensors
dev.coretemp.4.%parent: cpu4
dev.coretemp.4.%desc: CPU On-Die Thermal Sensors
dev.coretemp.3.%parent: cpu3
dev.coretemp.3.%desc: CPU On-Die Thermal Sensors
dev.coretemp.2.%parent: cpu2
dev.coretemp.2.%desc: CPU On-Die Thermal Sensors
dev.coretemp.1.%parent: cpu1
dev.coretemp.1.%desc: CPU On-Die Thermal Sensors
dev.coretemp.0.%parent: cpu0
dev.coretemp.0.%desc: CPU On-Die Thermal Sensors
dev.acpi_perf.7.%parent: cpu7
dev.acpi_perf.6.%parent: cpu6
dev.acpi_perf.5.%parent: cpu5
dev.acpi_perf.4.%parent: cpu4
dev.acpi_perf.3.%parent: cpu3
dev.acpi_perf.2.%parent: cpu2
dev.acpi_perf.1.%parent: cpu1
dev.acpi_perf.0.%parent: cpu0
dev.cpu.7.cx_method: C1/mwait/hwc C2/mwait/hwc C3/mwait/hwc
dev.cpu.7.cx_usage_counters: 2295465 7178352 0
dev.cpu.7.cx_usage: 24.22% 75.77% 0.00% last 450us
dev.cpu.7.cx_lowest: C2
dev.cpu.7.cx_supported: C1/1/1 C2/2/151 C3/3/256
dev.cpu.7.temperature: 53.0C
dev.cpu.7.coretemp.throttle_log: 0
dev.cpu.7.coretemp.tjmax: 100.0C
dev.cpu.7.coretemp.resolution: 1
dev.cpu.7.coretemp.delta: 47
dev.cpu.7.%parent: acpi0
dev.cpu.7.%pnpinfo: _HID=none _UID=0
dev.cpu.7.%location: handle=\_PR_.CPU7
dev.cpu.7.%driver: cpu
dev.cpu.7.%desc: ACPI CPU
dev.cpu.6.cx_method: C1/mwait/hwc C2/mwait/hwc C3/mwait/hwc
dev.cpu.6.cx_usage_counters: 2277594 7144830 0
dev.cpu.6.cx_usage: 24.17% 75.82% 0.00% last 107us
dev.cpu.6.cx_lowest: C2
dev.cpu.6.cx_supported: C1/1/1 C2/2/151 C3/3/256
dev.cpu.6.temperature: 53.0C
dev.cpu.6.coretemp.throttle_log: 0
dev.cpu.6.coretemp.tjmax: 100.0C
dev.cpu.6.coretemp.resolution: 1
dev.cpu.6.coretemp.delta: 47
dev.cpu.6.%parent: acpi0
dev.cpu.6.%pnpinfo: _HID=none _UID=0
dev.cpu.6.%location: handle=\_PR_.CPU6
dev.cpu.6.%driver: cpu
dev.cpu.6.%desc: ACPI CPU
dev.cpu.5.cx_method: C1/mwait/hwc C2/mwait/hwc C3/mwait/hwc
dev.cpu.5.cx_usage_counters: 2375287 7223183 0
dev.cpu.5.cx_usage: 24.74% 75.25% 0.00% last 105us
dev.cpu.5.cx_lowest: C2
dev.cpu.5.cx_supported: C1/1/1 C2/2/151 C3/3/256
dev.cpu.5.temperature: 53.0C
dev.cpu.5.coretemp.throttle_log: 0
dev.cpu.5.coretemp.tjmax: 100.0C
dev.cpu.5.coretemp.resolution: 1
dev.cpu.5.coretemp.delta: 47
dev.cpu.5.%parent: acpi0
dev.cpu.5.%pnpinfo: _HID=none _UID=0
dev.cpu.5.%location: handle=\_PR_.CPU5
dev.cpu.5.%driver: cpu
dev.cpu.5.%desc: ACPI CPU
dev.cpu.4.cx_method: C1/mwait/hwc C2/mwait/hwc C3/mwait/hwc
dev.cpu.4.cx_usage_counters: 2374905 7219176 0
dev.cpu.4.cx_usage: 24.75% 75.24% 0.00% last 40us
dev.cpu.4.cx_lowest: C2
dev.cpu.4.cx_supported: C1/1/1 C2/2/151 C3/3/256
dev.cpu.4.temperature: 53.0C
dev.cpu.4.coretemp.throttle_log: 0
dev.cpu.4.coretemp.tjmax: 100.0C
dev.cpu.4.coretemp.resolution: 1
dev.cpu.4.coretemp.delta: 47
dev.cpu.4.%parent: acpi0
dev.cpu.4.%pnpinfo: _HID=none _UID=0
dev.cpu.4.%location: handle=\_PR_.CPU4
dev.cpu.4.%driver: cpu
dev.cpu.4.%desc: ACPI CPU
dev.cpu.3.cx_method: C1/mwait/hwc C2/mwait/hwc C3/mwait/hwc
dev.cpu.3.cx_usage_counters: 2333769 7192754 0
dev.cpu.3.cx_usage: 24.49% 75.50% 0.00% last 33us
dev.cpu.3.cx_lowest: C2
dev.cpu.3.cx_supported: C1/1/1 C2/2/151 C3/3/256
dev.cpu.3.temperature: 54.0C
dev.cpu.3.coretemp.throttle_log: 0
dev.cpu.3.coretemp.tjmax: 100.0C
dev.cpu.3.coretemp.resolution: 1
dev.cpu.3.coretemp.delta: 46
dev.cpu.3.%parent: acpi0
dev.cpu.3.%pnpinfo: _HID=none _UID=0
dev.cpu.3.%location: handle=\_PR_.CPU3
dev.cpu.3.%driver: cpu
dev.cpu.3.%desc: ACPI CPU
dev.cpu.2.cx_method: C1/mwait/hwc C2/mwait/hwc C3/mwait/hwc
dev.cpu.2.cx_usage_counters: 2317010 7158361 0
dev.cpu.2.cx_usage: 24.45% 75.54% 0.00% last 81us
dev.cpu.2.cx_lowest: C2
dev.cpu.2.cx_supported: C1/1/1 C2/2/151 C3/3/256
dev.cpu.2.temperature: 54.0C
dev.cpu.2.coretemp.throttle_log: 0
dev.cpu.2.coretemp.tjmax: 100.0C
dev.cpu.2.coretemp.resolution: 1
dev.cpu.2.coretemp.delta: 46
dev.cpu.2.%parent: acpi0
dev.cpu.2.%pnpinfo: _HID=none _UID=0
dev.cpu.2.%location: handle=\_PR_.CPU2
dev.cpu.2.%driver: cpu
dev.cpu.2.%desc: ACPI CPU
dev.cpu.1.cx_method: C1/mwait/hwc C2/mwait/hwc C3/mwait/hwc
dev.cpu.1.cx_usage_counters: 2421898 7338610 0
dev.cpu.1.cx_usage: 24.81% 75.18% 0.00% last 52us
dev.cpu.1.cx_lowest: C2
dev.cpu.1.cx_supported: C1/1/1 C2/2/151 C3/3/256
dev.cpu.1.temperature: 53.0C
dev.cpu.1.coretemp.throttle_log: 0
dev.cpu.1.coretemp.tjmax: 100.0C
dev.cpu.1.coretemp.resolution: 1
dev.cpu.1.coretemp.delta: 47
dev.cpu.1.%parent: acpi0
dev.cpu.1.%pnpinfo: _HID=none _UID=0
dev.cpu.1.%location: handle=\_PR_.CPU1
dev.cpu.1.%driver: cpu
dev.cpu.1.%desc: ACPI CPU
dev.cpu.0.cx_method: C1/mwait/hwc C2/mwait/hwc C3/mwait/hwc
dev.cpu.0.cx_usage_counters: 2980441 14327306 0
dev.cpu.0.cx_usage: 17.22% 82.77% 0.00% last 104us
dev.cpu.0.cx_lowest: C2
dev.cpu.0.cx_supported: C1/1/1 C2/2/151 C3/3/256
dev.cpu.0.freq_levels: 3801/72000 3800/72000 3600/66145 3400/61191 3200/56425 29 00/49260 2700/44929 2500/40138 2300/36144 2100/32318 1900/28643 1700/24566 1400/ 19331 1200/16209 1000/13237 800/10403
dev.cpu.0.freq: 3801
dev.cpu.0.temperature: 53.0C
dev.cpu.0.coretemp.throttle_log: 0
dev.cpu.0.coretemp.tjmax: 100.0C
dev.cpu.0.coretemp.resolution: 1
dev.cpu.0.coretemp.delta: 47
dev.cpu.0.%parent: acpi0
dev.cpu.0.%pnpinfo: _HID=none _UID=0
dev.cpu.0.%location: handle=\_PR_.CPU0
dev.cpu.0.%driver: cpu
dev.cpu.0.%desc: ACPI CPU
dev.cpu.%parent:
security.jail.param.cpuset.id: 0
I would expect the
dev.cpu.xx.freq_levels to show 4200/(something), but maybe I'm just boned?
